Home » Eclipse Projects » BIRT » Localize drill through tooltip text
Localize drill through tooltip text [message #757517] Fri, 18 November 2011 12:55 Go to next message
donino donino is currently offline donino donino
Member
When building a drill-through type hyperlink in designer, on step 6, we can enter a tooltip text wich will be displayed on hyperlink mouseover. I wonder if there is a way to localize this text? Usually in birt designer we can select a key for these kind of labels but not here. Please do someone know a way to localize this text?
thanks !
Re: Localize drill through tooltip text [message #757838 is a reply to message #757517] Fri, 18 November 2011 17:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Why not just remove the tooltip and use an oncreate script for the data
item like:
this.helpText = reportContext.getMessage("text1",
reportContext.getLocale());
Jason
On 11/18/2011 12:55 PM, dpardon wrote:
> thanks !
Jason Weathersby
BIRT Exchange
Re: Localize drill through tooltip text [message #758212 is a reply to message #757838] Tue, 22 November 2011 06:02 Go to previous messageGo to next message
Member
it perfectly works, thanks!
Re: Localize drill through tooltip text [message #956273 is a reply to message #757517] Wed, 24 October 2012 07:28 Go to previous message
Ingoos Ficher is currently offline Ingoos Ficher
Thanks Smile ... just what i needed Smile
Previous Topic:DataException from 3.7 runtime when rpt designs have scripts
Next Topic:pie chart sorting
Current Time: Sat May 25 09:37:15 EDT 2013
Powered by FUDForum. Page generated in 0.07474 seconds
