| Java Model Exception when executing Xtend functions [message #757252] |
Thu, 17 November 2011 05:57  |
Vitali Gontsharuk Messages: 2 Registered: November 2011 |
Junior Member |
Dear forum members,
I'm experiencing a rather frustrating Eclipse Console and log flooding with Java Model Exceptions, which I sadly have been unable to find a solution for.
I'm running a series of M2M and M2T transformations using Xtend and Xpand through Ant (same JRE as Eclipse). I'm starting Eclipse from another Eclipse instance, if that plays any role. It seems that whenever the Xtend engine is accessing an Ecore model, a Java Model Exception is thrown. But this does not hinder the corresponding Xtend function / Xpand define from executing correctly.
Do you have any idea why this could be happening?
Here is a typical stack trace I'm getting for each model access:
!ENTRY org.eclipse.xtend.ui 4 0 2011-11-17 11:39:15.481
!MESSAGE .org.eclipse.jdt.core.external.folders does not exist
!STACK 1
Java Model Exception: Java Model Status [.org.eclipse.jdt.core.external.folders does not exist]
at org.eclipse.jdt.internal.core.JavaElement.newJavaModelException(JavaElement.java:502)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:246)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:515)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:252)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:238)
at org.eclipse.jdt.internal.core.JavaProject.getJavaProjectElementInfo(JavaProject.java:1603)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(JavaProject.java:2282)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(JavaProject.java:2292)
at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProject.java:1321)
at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProject.java:1228)
at org.eclipse.xtend.ui.core.internal.builder.PluginJavaExtensionStatement.analyzeInternal(PluginJavaExtensionStatement.java:48)
at org.eclipse.internal.xtend.xtend.ast.AbstractExtension.analyze(AbstractExtension.java:126)
at org.eclipse.internal.xtend.xtend.ast.ExtensionFile.analyze(ExtensionFile.java:116)
at org.eclipse.xtend.ui.core.internal.XtendResourceImpl.analyze(XtendResourceImpl.java:49)
at org.eclipse.internal.xpand2.ast.ExtensionImportDeclaration.analyze(ExtensionImportDeclaration.java:42)
at org.eclipse.internal.xpand2.ast.Template.analyze(Template.java:126)
at org.eclipse.xpand.ui.core.internal.XpandResourceImpl.analyze(XpandResourceImpl.java:45)
at org.eclipse.xtend.shared.ui.core.AbstractResource.analyze(AbstractResource.java:90)
at org.eclipse.xtend.shared.ui.core.internal.XtendXpandProject.analyze(XtendXpandProject.java:338)
at org.eclipse.xtend.shared.ui.core.builder.XtendXpandBuilder.build(XtendXpandBuilder.java:201)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:629)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:172)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:203)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:255)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:258)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:311)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:343)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2011-11-17 11:39:15.482
Here is a short spec of my installation:
Eclipse Version: 3.6.2
eclipse.buildId=M20110210-1200
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data X:\eclipse_workspaces2\workspace_tools/../workspace_apps -dev file:X:/eclipse_workspaces2/workspace_tools/.metadata/.plugins/org.eclipse.pde.core/m2m/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
Any help is kindly appreciated!
Vitali
[Updated on: Thu, 17 November 2011 06:10] Report message to a moderator
FUDForum. Page generated in 0.01658 seconds
