Enabling Remote Event Service in OSEE [message #757247] |
Thu, 17 November 2011 05:33 |
Swapna Missing name Messages: 9 Registered: July 2009 |
Junior Member |
I was trying to deploy remote client & server , it worked fine but with multi client i faced the problem of refresh and synchronization. If anyone else is also facing the same problem then to fix this please follow the steps below :
1. goto OSEE preferences -> check Configuration details page -> check the Remote Event column
2. if the result is Ok then the remote event service is running and clients are in sync.
3. if is says unavailable - ActiveMQ JMS service is down, then 2 things are to be checked.
3.a) check if there is a ActiveMQ running on the server
3.b) the client configuration should be updated with argument
-Dosee.default.broker.uri=tcp://<localhost_or_your_server>:61616
please refere this link for further info :
http://wiki.eclipse.org/OSEE/Users_Guide/Getting_Started#Messaging_Service.
regards,
Swapna
FUDForum. Page generated in 0.22186 seconds
