Home » Eclipse Projects » Web Tools Project (WTP) » Timeout calling webservice(How do I set timeout in my client?)
Timeout calling webservice [message #757232] Thu, 17 November 2011 04:30 Go to next message
Peter  is currently offline Peter
I have installed WTP in my Eclipse 3.6.2, so I can write a java client to a webservice written in .net (actually it's a WCF service). I have managed to get basic connectivity established - and even managed to call some test methods on the webservice and obtain results.
However, one webservice method returns a large amount of data, and takes a long time to run. I always get timeouts when calling this method. How do I increase the timeout in my WTP java client, so I can successfully call this method? Will I also need to increase the acceptable reponse-size in my client?
Peter
Re: Timeout calling webservice [message #758342 is a reply to message #757232] Tue, 22 November 2011 15:40 Go to previous message
Keith Chong is currently offline Keith Chong
Member
It depends on the technology that your Web service client is running against.
So, if for Axis, check this thread out:
http://www.coderanch.com/t/222574/Web-Services/java/Time-out-org-apache-axis
Previous Topic:CMDocument for an internal subset?
Next Topic:"static" confusion in JSDT auto completion proposals
Current Time: Sun May 19 23:52:04 EDT 2013
Powered by FUDForum. Page generated in 0.06105 seconds
