Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Java-Content-Assist inside jruby-script possible?
Java-Content-Assist inside jruby-script possible? [message #757195] Wed, 16 November 2011 22:47
Al Bundy is currently offline Al Bundy
I have to implement some ruby-scripts from time to time.
Inside my scripts I have to use some of our own java-classes and -interfaces.
Is there a way to enable code-completion for the java-classes?
Just a small example
require 'java'
java_import 'java.util.HashMap'
m = HashMap.new
In the next line I want to write m.c and press ctrl+space to see, that I can use the method "clear"
The current proposals are
captures() - Matcher
case
class
Is it possible to enable code-completion for java-classes?
Al
Previous Topic:Is org.eclipse.ltk.core.refactoring.createParticipants working ?
Next Topic:Interface usage in DBGP debugger
Current Time: Sat May 18 06:33:49 EDT 2013
Powered by FUDForum. Page generated in 0.01412 seconds
