Home » Modeling » EMF » TableViewer data binding with EMF model - Problems syncing number columns
TableViewer data binding with EMF model - Problems syncing number columns [message #756315] Fri, 11 November 2011 17:11 Go to next message
Stein Erik is currently offline Stein Erik
I have problems synchronizing table columns with non-String EMF attributes when the content of a column cell is updated interactively. Things runs smoothly for String (Target) to EString (EMF Model) sync.
I hoped the type conversion was either performed automatically, or an UpdateValueStrategy could be injected easily. But, cannot figure it out! Suspect there is something fundamental that I am missing...
EMFDataBindingContext and ObservableValueEditingSupport.create(....) are used (in my class ProjectInfoView.java).
Please find an attached test case w/a small EMF model. (The DEFAULT_PATH constant in CampliModelXMIResource.java needs to be updated by a user in order to read the EMF model from the included xmi file)
The Table appears when either the nodes "Pampas" or "Hurramegrundt" is selected in the Model Explorer View. Then you are ready to try interactively updating the model for different data types.
I have tried running this on Mac and Windows, same performance. Using Eclipse 3.7, Indigo.
Help appreciated! Thanks Stein Erik
[Updated on: Fri, 11 November 2011 17:13]
Report message to a moderator
Re: TableViewer data binding with EMF model - Problems syncing number columns [message #756332 is a reply to message #756315] Sat, 12 November 2011 01:23 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Am 11.11.11 23:11, schrieb Stein Erik:
> I hoped the type conversion was either performed automatically, or an UpdateValueStrategy could be injected easily. But, bannot figure it out! Suspect there is something fundamental that I am missing...
> EMFDataBindingContext og ObservableValueEditingSupport.create(....) are used (in my class ProjectInfoView.java).
So is the problem performance or that you don't get a conversion support
when it comes to none string values like float, Float, ... and if it the
conversion support which one is not working as expected?
Tom
Re: TableViewer data binding with EMF model - Problems syncing number columns [message #756416 is a reply to message #756332] Sat, 12 November 2011 18:00 Go to previous messageGo to next message
Tom Schindl wrote on Sat, 12 November 2011 01:23
Tom
Thanks for follow-up (and btw thx for all your nice tutorials and example codes).
I have not experienced any performance issues to date, it's a functionality issue. Summary at the bottom. Some details first:
(I) JFace TableViewer - EMF Databinding (test in my 'ProjectInfoView')
Using TableViewer/EMFDataBindingContext/ObservableValueEditingSupport/ TextCellEditor, the conversion String (Target) - EString (Model) works.
Not working: Automated conversion for String - EInt/EIntegerObject/EFloat/EFloatObject/EDouble/EDoubleObject/EBoolean/EBooleanObject
//Extract from text code
final TableViewer viewer = new TableViewer(composite, SWT.FULL_SELECTION | SWT.BORDER | SWT.MULTI | SWT.CHECK);
ObservableListContentProvider cp = new ObservableListContentProvider();
viewer.setContentProvider(cp);
IValueProperty property = EMFEditProperties.value(editingDomain, CamplioPackage.Literals.VENDOR__VALUE_INTEGER_OBJECT);
TableViewerColumn column = new TableViewerColumn(viewer, SWT.LEAD);
column.getColumn().setText("EIntegerObject");
column.getColumn().setWidth(100);
column.getColumn().setMoveable(true);
column.setLabelProvider(new ObservableMapCellLabelProvider(property.observeDetail(set)));
// make column editable
column.setEditingSupport(ObservableValueEditingSupport
		.create(viewer,
				dbc, // EMFDataBindingContext
				new TextCellEditor(table),
				CellEditorProperties.control().value(WidgetProperties.text(SWT.Modify)),
				property));
(II) SWT Widget - EMF DataBinding (test in 'InformationFormView')
Works nicely, no problem for any of the data types listed above.
Summary of my concerns for TableViewer-EMF Databinding; (a) Automated data type conversion does not seem to work for most datatypes, and (b) I cannot find an easy way to inject an UpdateValueStrategy for customized conversion & validation (hints appreciated!).
Attached is updated & extended test code.
[Updated on: Sat, 12 November 2011 18:02]
Re: TableViewer data binding with EMF model - Problems syncing number columns [message #756438 is a reply to message #756416] Sun, 13 November 2011 05:46 Go to previous messageGo to next message
Ok I think I see the problem.
The ObservableValueEditingSupport is creating a UpdateValueStrategy
which is a problem when used with am EMF-Observable because the target
type there is the EStructuraleFeature and the features type and so the
conversion between those is not working as expected.
I've attached you a specialized EditingSupport which fixes this by
creating an EMFUpdateValueStrategy.
Tom
Am 13.11.11 00:00, schrieb Stein Erik:
>> Tom
> Using TableViewer, EMFDataBindingContext, ObservableValueEditingSupport, TextCellEditor the conversion from String (Target) - EString (Model) works.
> .create(viewer,
> property));
> Summary of my concerns for TableViewer-EMF Databinding; (a) Automated data type conversion does not seem to work for most datatypes, and (b) I cannot find an easy way to inject an UpdateValueStrategy for customized conversion& validation (hints appreciated!).
> Attached is updated& extended test code.
package aa.camplio.viewexample.views.util;
import org.eclipse.core.databinding.Binding;
import org.eclipse.core.databinding.UpdateValueStrategy;
import org.eclipse.core.databinding.observable.value.IObservableValue;
import org.eclipse.core.databinding.property.value.IValueProperty;
import org.eclipse.emf.databinding.EMFDataBindingContext;
import org.eclipse.emf.databinding.EMFUpdateValueStrategy;
import org.eclipse.jface.databinding.viewers.ObservableValueEditingSupport;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.ViewerCell;
public abstract class EMFObservableValueEditingSupport extends ObservableValueEditingSupport {
private EMFDataBindingContext dbc;
public EMFObservableValueEditingSupport(ColumnViewer viewer,
EMFDataBindingContext dbc) {
super(viewer, dbc);
this.dbc = dbc;
public static EditingSupport create(ColumnViewer viewer,
EMFDataBindingContext dbc, final CellEditor cellEditor,
final IValueProperty cellEditorProperty,
final IValueProperty elementProperty) {
return new EMFObservableValueEditingSupport(viewer, dbc) {
protected IObservableValue doCreateCellEditorObservable(
CellEditor cellEditor) {
return cellEditorProperty.observe(cellEditor);
protected IObservableValue doCreateElementObservable(
Object element, ViewerCell cell) {
return elementProperty.observe(element);
protected CellEditor getCellEditor(Object element) {
return cellEditor;
protected Binding createBinding(IObservableValue target,
IObservableValue model) {
return dbc.bindValue(target, model, new EMFUpdateValueStrategy(
UpdateValueStrategy.POLICY_CONVERT), null);
Re: TableViewer data binding with EMF model - Problems syncing number columns [message #756469 is a reply to message #756438] Sun, 13 November 2011 13:33 Go to previous messageGo to next message
Thx Tom, that made wonders!
I wish I had the skills to understand what's going on under the hood of the Databinding APIs so that I could make such improvements and contribute myself. And I will attempt that in the near future;
Approx one month from now I will revert to try injecting customized conversion & validation in the TableViewerColumn - EMF databinding pipeline. The idea is to use UpdateValueStrategy for two-way, on-the-fly unit conversion (e.g. 'length' displayed as km, metres, dm, cm, mm, inch, ft, etc. while the model always store the length value in SI metric metres).
[Updated on: Sun, 13 November 2011 13:34]
icon14.gif  Re: TableViewer data binding with EMF model - Problems syncing number columns [message #756876 is a reply to message #756469] Tue, 15 November 2011 07:23 Go to previous message
Bernard SARTER is currently offline Bernard SARTER
Member
Hello Tom and Erik,
I was stuck with the same problem since quite a while, and your clear and complete example and associated solution worked for me as well, thanks a lot !
Bernard.
Previous Topic:Can I use EMF to build tooling for an XML based standard?
Next Topic:[Databinding] empty child list and IObservable creation.
Current Time: Wed May 22 19:31:35 EDT 2013
Powered by FUDForum. Page generated in 0.01766 seconds
