Home » Eclipse Projects » BIRT » PHP BIRT - Delete Session Folders(Advise Deleting Session Folders)
PHP BIRT - Delete Session Folders [message #756187] Fri, 11 November 2011 07:24 Go to next message
karvesh ghunsam is currently offline karvesh ghunsam
Member
Dear All,
The integration of php with BIRT entails the creation of session folders containing the rptdocument files.
I have created a batch file with the simple code:
forfiles -p "C:\what\ever" -s -m *.* -d <number of days> -c "cmd /c del @path"
that will delete all session folders older than any specific number of days
However, i am having some trouble to do it because my Tomcat server is running all time and the process seems to lock the rptdocument files in the session folders.
Any advise how to overcome that problem? The issue is that the session folders are cropping rapidly on the server..
Thanks in advance
Karvesh
Re: PHP BIRT - Delete Session Folders [message #756231 is a reply to message #756187] Fri, 11 November 2011 10:16 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Are you using the php Java Bridge or the BIRT Viewer on tomcat?
Jason
On 11/11/2011 7:24 AM, karvesh wrote:
> Dear All,
> @path"
> Thanks in advance
> Karvesh
Jason Weathersby
BIRT Exchange
Re: PHP BIRT - Delete Session Folders [message #756328 is a reply to message #756231] Fri, 11 November 2011 22:39 Go to previous messageGo to next message
Member
Dear Jason
Its the javabridge..
I noted that when i stop Tomcat, i can delete the session folders.. Is there another way to delete them with out having to stop tomcat?
Karvesh
Re: PHP BIRT - Delete Session Folders [message #756650 is a reply to message #756328] Mon, 14 November 2011 10:14 Go to previous messageGo to next message
There appears to be a bug in some of the render samples, where the
document is not being closed:
$task->render();
$document->close();
$task->close();
Make sure you are closing the documents after every render operation and
then your delete code should work. I just tested this to verify.
Jason
On 11/11/2011 10:39 PM, karvesh wrote:
> Dear Jason
> Karvesh
Jason Weathersby
BIRT Exchange
Re: PHP BIRT - Delete Session Folders [message #756773 is a reply to message #756650] Mon, 14 November 2011 22:03 Go to previous message
Member
Dear Jason
It is working fine now.. I indeed missed the close document code.. Smile
Thanks a lot!!
Cheers
Karvesh
Previous Topic:BIRT 3.7 Deployed in a Java Web Start (Jnlp) Stand Alone App
Next Topic:Birt Missing images on ProxyPass
Current Time: Tue May 21 10:26:01 EDT 2013
Powered by FUDForum. Page generated in 0.01630 seconds
