| null LEAKING ClassLoader [message #748138] |
Mon, 24 October 2011 10:09  |
stefano zanchin Messages: 2 Registered: October 2011 |
Junior Member |
Hi guys,
during memory analizer of our application deployed in IBM WAS 6.1.
I found end fix same memory leak, static class and reference of object Circular and complex bi-directional references, cleaning object in click of the menu(not related to login), fix release of sessionMemoryObject in change site/close windows.
So now I don't have more idea for reduce usage memory..
We have a JEE EAR web application with more than one Java Jar project made by us and we using this principal thirt part lib icefaces,jsf,facelets,spring,hibernate,cxf ecc. with JRE 1.5.
We have yet OutOfMemory(OOM) during automatic test case
My last step of analisys is..
start test in my local Server, after 30 minute, stop test and verify status of memory in server, forcing dump of memory server.
Now my question:
what is null LEAKING LOADER?(see attachment)
is a classLoader memory leak?
how can I understand and solve this type of issue!? (If it is a issue..)
many Thanks, Ste
P.s. when I post more that 5 message I can put also the image and Link, if required.
| Re: null LEAKING ClassLoader [message #756722 is a reply to message #753732] |
Mon, 14 November 2011 14:54  |
Kevin Grigorenko Messages: 1 Registered: November 2011 |
Junior Member |
Stefano, the "null LEAKING LOADER" is indeed part of the IBM Extensions for Memory Analyzer (IEMA) plugins. IEMA has a name resolver for instances of com.ibm.ws.classloader.CompoundClassLoader. The resolver will run some heuristics to see if the CompoundClassLoader is likely to be a leak. The reason it says "null" in front of LEAKING LOADER is that we try to get the name of the application but with a PHD there are no Strings. I will modify it to not print null. We have recently revamped the leaking classloader analysis, so to further investigate, run IBM Extensions > WebSphere Application Server > Class Loaders > Path to Leaking Application Classloaders.
Basically, this is usually caused by a static object or ThreadLocal holding a reference to something in the class graph of the CompoundClassLoader (or a child CompoundClassLoader). This means that if you update an application or stop an application, the CompoundClassLoader cannot be garbage collected. If this happens enough, this can cause native or Java OutOfMemoryErrors.
FUDForum. Page generated in 0.01617 seconds
