Home » Eclipse Projects » EclipseLink » Select from partition ?
Select from partition ? [message #756678] Mon, 14 November 2011 11:08 Go to next message
Krzysztof Kowalczyk is currently offline Krzysztof Kowalczyk
I have an application running on Oracle and EclipseLink 2.1(if really needed I can upgrade it) using the old ExpressionBuilder api. I would like to optimise a long running query to use only one known partition.
Is it possible to construct a query that use both: a bit of native SQL (From x partition(y)) and ExpressionBuilder api for the rest of query?
Krzysztof Kowalczyk
Re: Select from partition ? [message #757803 is a reply to message #756678] Mon, 21 November 2011 13:12 Go to previous message
James Sutherland is currently offline James Sutherland
It is probably better to use an SQL query then try to mix objects and SQL.
You can use the getTable() API to get a table reference, but I don't think you could generate what you want. EclipseLink's AsOfClause does do something similar in syntax.
James : Wiki : Book : Blog
Previous Topic:OnetoOne mapping issue
Next Topic:Select from partition ?
Current Time: Thu May 23 09:23:47 EDT 2013
Powered by FUDForum. Page generated in 0.09587 seconds
