Home » Eclipse Projects » DSDP - Target Management » SSH Terminal Colors(How do I change the terminal colors?)
icon5.gif  SSH Terminal Colors [message #629560] Tue, 28 September 2010 13:12 Go to next message
No real name is currently offline No real name
I'm new to Eclipse, so this may be a question I should know the answer to. I've done a lot of googling and haven't found an answer yet.
I'm using the SSH Terminal in RSE and I would like to change the terminal window's colors.
Can anyone point me in the right direction?
Re: SSH Terminal Colors [message #639418 is a reply to message #629560] Tue, 16 November 2010 08:30 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
the terminal colors are determined by the remote system. If your remote
computer paints something blue, you're expected to see it as blue.
What you can do, is invert terminal colors, ie use white-on-black fonts
rather than the default black-on-white. You can do so via Preferences :
Terminal.
Any other change of colors must be done in your remote system.
Martin
Re: SSH Terminal Colors [message #656198 is a reply to message #639418] Thu, 24 February 2011 09:38 Go to previous messageGo to next message
Stuart Jennings is currently offline Stuart Jennings
I'm having the same issue. The fix you've suggested doesn't work for the SSH Terminals, only for the Target Management Terminal. For some reason, a terminal created from the RSE UI (expanding the remote connection, right clicking on the SSH Terminals and selecting Launch Terminal) doesn't appear to use the TM Terminal settings.
Any ideas?
Stuart.
Re: SSH Terminal Colors [message #756627 is a reply to message #656198] Mon, 14 November 2011 09:30 Go to previous message
Daniel Sokolowski is currently offline Daniel Sokolowski
Same issue here with 'invert colors' --- selecting it does not work for me --- I am using Target Management Terminal 3.2.1.R33x_v201106281309-7N7B1BbVJv-SaPEOkhsVVd_C3752
Previous Topic:How to change background color of ssh terminal window?
Next Topic:Target Management
Current Time: Wed May 29 03:38:10 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
