Home » Eclipse Projects » Plugin Development Environment (PDE) » Error Log and console output
Error Log and console output [message #756297] Fri, 11 November 2011 15:03 Go to next message
Lucy Sakhnenko is currently offline Lucy Sakhnenko
Member
I'm sending the exceptions of my plugin to the Error Log. This is an example built from the "Hello World" sample puging project:
	@SuppressWarnings("null")
	public void run(IAction action) {
		MessageDialog.openInformation(
			window.getShell(),
			"Test",
			"Hello, Eclipse world");
		Bundle bundle = Platform.getBundle(Platform.PI_RUNTIME);
		ILog log = Platform.getLog(bundle);
		Object o = null;
		try {
			o.equals("sk");
		} catch (Exception e) {
			log.log(new Status(Status.ERROR, "MyPI", "test", e));
Everything works fine, but the exception keeps showing up in the Eclipse console:
!ENTRY MyPI 4 0 2011-11-11 15:36:23.116
!MESSAGE test
!STACK 0
	at test.actions.SampleAction.run(SampleAction.java:50)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
I was hoping to not see the exception written in the console anymore.
Is this how it is supposed to work or I am doing something wrong?
Thanks!
Re: Error Log and console output [message #757349 is a reply to message #756297] Thu, 17 November 2011 15:47 Go to previous message
Mark Walters is currently offline Mark Walters
perhaps you are starting eclipse with -consoleLog. The docs imply this:
http://wiki.eclipse.org/FAQ_How_do_I_use_the_platform_logging_facility%3F
Ta,
Mark.
Previous Topic:Connecting IOConsole to an invoked Process
Next Topic:PluginRegistry.getActiveModels() doesn't work properly
Current Time: Tue May 21 11:34:51 EDT 2013
Powered by FUDForum. Page generated in 0.01544 seconds
