| DatabaseQuery - not possible to drop to Canvas [message #755648] |
Wed, 09 November 2011 03:29  |
fantasia1993 Messages: 6 Registered: November 2011 |
Junior Member |
If i Drag and Drop a DatabaseQuery to Canvas, it disappears at the moment, when i drop it. If i save the Canvas later on, following Null-Pointer Exception appears in Eclipse:
Paste it from Eclipse workspace: \.metadata\.log
see logging below...
Installed Components:
- Java6
- Eclipse V3.7.0
- OpenVXML 4.0 (Installed by this Link inside Eclipse: /download.eclipse.org/technology/vtp/helios/
Anyone else, that has the same Problem? Is it possible to use DatabaseQuery Modules in Open VXML 4.0?
Thanks in advance for any ideas and comments!
Wolfgang
logging of Eclipse workspace: \.metadata\.log:
!SESSION 2011-11-09 09:26:46.730 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.vtp.desktop.editors.core 4 0 2011-11-09 09:28:07.632
!MESSAGE Could not save file: /VTP_WE_App/Workflow Design/Main Canvas.canvas
!STACK 0
at org.eclipse.vtp.desktop.model.elements.core.internal.PrimitiveElement.writeCustomConfiguration(PrimitiveElement.java:92)
at org.eclipse.vtp.desktop.model.core.internal.DesignWriter.writeElementData(DesignWriter.java:104)
at org.eclipse.vtp.desktop.model.core.internal.DesignWriter.writeDesign(DesignWriter.java:58)
at org.eclipse.vtp.desktop.model.core.internal.DesignWriter.writeDesign(DesignWriter.java:30)
at org.eclipse.vtp.desktop.model.core.internal.DesignDocument.commitWorkingCopy(DesignDocument.java:197)
at org.eclipse.vtp.desktop.editors.core.impl.ApplicationEditor.doSave(ApplicationEditor.java:577)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper.java:151)
at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper.java:277)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2642)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:285)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:264)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:156)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager.java:1399)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage.java:3416)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3429)
at org.eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:54)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:468)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:786)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:885)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequenceBindings(WorkbenchKeyboard.java:567)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyboard.java:508)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.handleEvent(WorkbenchKeyboard.java:123)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1509)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2530)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
| Re: DatabaseQuery - not possible to drop to Canvas [message #755871 is a reply to message #755648] |
Wed, 09 November 2011 17:09   |
Randy Childers Messages: 121 Registered: July 2009 |
Hi Wolfgang--
I'm sorry you were blocked by this, but I'm happy to say we've just
fixed the problem. If you're compiling from source, go ahead and update
now and you should be good to go. If you're using the VTP update site,
the update should be available for you tomorrow.
Thank you and good luck--
Randy
> Pointer Exception appears in Eclipse: Paste it from Eclipse workspace: \.
> metadata\.log see logging below...
> - Java6
> - Eclipse V3.7.0
> Wolfgang
> 632 !MESSAGE Could not save file: /VTP_WE_App/Workflow Design/Main
> Canvas.canvas !STACK 0 java.lang.NullPointerException at org.eclipse.
> writeCustomConfiguration(PrimitiveElement.java:92) at org.eclipse.vtp.
> java:104) at org.eclipse.vtp.desktop.model.core.internal.DesignWriter.
> writeDesign(DesignWriter.java:58) at org.eclipse.vtp.desktop.model.
> core.internal.DesignWriter.writeDesign(DesignWriter.java:30) at org.
> commitWorkingCopy(DesignDocument.java:197) at org.eclipse.vtp.desktop.
> 151) at org.eclipse.ui.internal.SaveableHelper$5.run(SaveableHelper.
> java:277) at org.eclipse.jface.operation.ModalContext.
> runInCurrentThread(ModalContext.java:464) at org.eclipse.jface.
> operation.ModalContext.run(ModalContext.java:372) at org.eclipse.
> jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759) at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> java:756) at org.eclipse.ui.internal.WorkbenchWindow.run(
> WorkbenchWindow.java:2642) at org.eclipse.ui.internal.SaveableHelper.
> runProgressMonitorOperation(SaveableHelper.java:285) at org.eclipse.
> java:264) at org.eclipse.ui.internal.SaveableHelper.savePart(
> SaveableHelper.java:156) at org.eclipse.ui.internal.EditorManager.
> savePart(EditorManager.java:1399) at org.eclipse.ui.internal.
> WorkbenchPage.savePart(WorkbenchPage.java:3416) at org.eclipse.ui.
> internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3429) at org.
> java:293) at org.eclipse.core.commands.Command.executeWithChecks(
> Command.java:476) at org.eclipse.core.commands.ParameterizedCommand.
> executeWithChecks(ParameterizedCommand.java:508) at org.eclipse.ui.
> 169) at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(
> WorkbenchKeyboard.java:468) at org.eclipse.ui.internal.keys.
> WorkbenchKeyboard.press(WorkbenchKeyboard.java:786) at org.eclipse.ui.
> 885) at org.eclipse.ui.internal.keys.WorkbenchKeyboard.
> filterKeySequenceBindings(WorkbenchKeyboard.java:567) at org.eclipse.
> handleEvent(WorkbenchKeyboard.java:123) at org.eclipse.swt.widgets.
> EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.
> Display.filterEvent(Display.java:1262) at org.eclipse.swt.widgets.
> Widget.sendEvent(Widget.java:1052) at org.eclipse.swt.widgets.Widget.
> sendEvent(Widget.java:1077) at org.eclipse.swt.widgets.Widget.
> sendEvent(Widget.java:1062) at org.eclipse.swt.widgets.Widget.
> sendKeyEvent(Widget.java:1104) at org.eclipse.swt.widgets.Widget.
> sendKeyEvent(Widget.java:1100) at org.eclipse.swt.widgets.Widget.
> wmChar(Widget.java:1509) at org.eclipse.swt.widgets.Control.WM_CHAR(
> Control.java:4640) at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.
> java:345) at org.eclipse.swt.widgets.Control.windowProc(Control.java:
> 4528) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972) at
> org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method) at
> org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2530) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752) at
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660) at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at
> org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at org.
> eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:
> 332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(
> Workbench.java:667) at org.eclipse.ui.PlatformUI.
> createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.
> ide.application.IDEApplication.start(IDEApplication.java:123) at org.
> eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.
> java:196) at org.eclipse.core.runtime.internal.adaptor.
> EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.
> eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(
> EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.
> EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.
> runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.
> reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.
> 39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(
> DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.
> invoke(Method.java:597) at org.eclipse.equinox.launcher.Main.
> invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.
> basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.
> java:1410)
| Re: DatabaseQuery - not possible to drop to Canvas [message #756046 is a reply to message #756001] |
Thu, 10 November 2011 10:53  |
Hi Wolfgang--
This was an error we inadvertantly introduced when trying to improve
support for using git -- it's been fixed, and the build process for our
update server has been kicked off, so the update should be available via
the update site in about 10 minutes.
good luck,
Randy
In <j9gglc$mpd$1@news.eclipse.org> fantasia1993 wrote:
> Hi Randy,
> thanks for the fast response and fix of the problem!!!
> For the first test i used a very simple Database-Query Block.
> Now, i have a Problem when exporting the Application to war-file.
> Following error occurs:
> Error Exporting Web Application
> org.xml.sax.SAXParseException: Content is not allowed in prolog.
> Is there a log, where more details can be found?
> Is this also a bug?
> Thanks in advance for comments!
> Wolfgang
FUDForum. Page generated in 0.01800 seconds
