Home » Modeling » Graphiti » Content assistant provided?
Content assistant provided? [message #755805] Wed, 09 November 2011 11:13 Go to next message
Eclipse User
Hey,
is there a way to support content assistance while direct editing of
texts with graphiti? I'd like to add a Content Assistant for OCL
expressions.
best regards,
Lilija
Re: Content assistant provided? [message #755811 is a reply to message #755805] Wed, 09 November 2011 11:24 Go to previous messageGo to next message
Jos Warmer is currently offline Jos Warmer
Alexander Nyßen had a preentation on work done to include Xtext editors inside GMF. See http://eclipsecon.org/sessions/tmf-meets-gmf-combining-graphical-and-textual-modeling.
This turned out to almost be GMF independent, and is a good basis for getting this inside Graphiti. This can solve your problem.
Jos
Re: Content assistant provided? [message #755972 is a reply to message #755805] Thu, 10 November 2011 05:58 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Besides to what Jos wrote, you can provide copletion values by implementing
AbstrctDirectEditingFeature.getValueProposals for text edit fields.
HTH,
Michael
Re: Content assistant provided? [message #999944 is a reply to message #755972] Sun, 13 January 2013 09:14 Go to previous messageGo to next message
Andreas Graf is currently offline Andreas Graf
Hi all,
I have implemented a test of content assist by putting
    	public String[] getValueProposals(String value, int caretPos,
    			IDirectEditingContext context) {
    		System.out.println("___________________________");
    		return new String[] {"A","B"};
in my direct editing feature. However, the code does not seem to be called. What is the keycode to invoke the content assist in a direct editing text?
Andreas
Re: Content assistant provided? [message #1000332 is a reply to message #999944] Mon, 14 January 2013 09:42 Go to previous message
Andreas,
the key to invoke auto completion is CTRL-Space (as in standard Eclipse text
editors). Did you enable auto completion in your direct editing feature by
retunring true in the methods isCompletionAvailable and
isAutoCompletionEnabled?
Michael
Previous Topic:How do I link by ID instead of hierarchy
Next Topic:Style with LineWidth and LineStyle does not work
Current Time: Mon May 20 00:43:35 EDT 2013
Powered by FUDForum. Page generated in 0.01941 seconds
