| Migrating from spring-dm to blueprint [message #755649] |
Wed, 09 November 2011 03:30  |
I made an example using PAX and Spring-DM running well.
With Blueprint as a future of Spr-DM, I would like to migrate the Spring-DM framework.
But Blueprint has no web support and Virgo is not as modular to be platform agnostic.
Is there an alternative to realize this?
My example is free and available here, you can use it, improve it and, if you've got the time, replace DM with Blueprint:
http://hudson.osgiliath.net/job/orthank-sample%20Tag/ws/
In order to compile, you just need to have maven 3 and run: mvn clean install -DskipTests=true (integration tests are not stable for now).
Then, in order to launch run: mvn pax:provision -Dframework=equinox (or -Dframework=felix) and point your browser to http://localhost:8080/net.osgiliath.orthank-sample.java.web.simple_1.0.1.SNAPSHOT
You'll be able to say hello with web services.
You can désactivate ws client module to run it without ws.
Charlie (tcharl on twitter, cmordant1@gmail.com on gtalk)
FUDForum. Page generated in 0.07801 seconds
