Home » Eclipse Projects » EclipseLink » Calling preparedStatement/Function the JPA way
Calling preparedStatement/Function the JPA way [message #755448] Tue, 08 November 2011 09:53
Neikius Mising name is currently offline Neikius Mising name
Member
Well, the JPA documentation suggests this:
http://en.wikibooks.org/wiki/Java_Persistence/Advanced_Topics#Stored_Procedures
EntityManager em = getEntityManager();
Query query = em.createNativeQuery("BEGIN VALIDATE_EMP(P_EMP_ID=>?); END;");
query.setParameter(1, empId);
query.executeUpdate();
But this doesn't work for me.
Caused by: java.lang.IllegalStateException: You cannot call executeUpdate() on this query. It is the incorrect query type.
I guess EclipseLink has its own PreparedStatement/Function methods. But how do you invoke that using injected container-managed EntityManager? I know how to do stuff using EclipseLink Session construct, but inside this EJB context I just cannot get Session... clues, help? I am just stuck on this at every corner. Well, I can still get the connection direcly, but would like to avoid that if possible since I have managed to fetch data using JPA.
Is it worth trying at all?
EDIT: Oh sneaky stuff. I think I got this figured. I was calling
Query query = em.createNativeQuery("BEGIN VALIDATE_EMP(P_EMP_ID=>?); END;", Entity.class);
Mind that class parameter at the end. That probably defaults the query created to ReadAllQuery ... If I remove the parameter at the end I get a DataModifyQuery as it is supposed to be. This one was trivial. I am leaving this post in. Maybe someone else can profit from my stupid mistakes.
[Updated on: Tue, 08 November 2011 10:13]
Report message to a moderator
Previous Topic:DescriptorQueryManager+EntityManager
Next Topic:Failed to map sql result set when execute stored procedure returning cursor
Current Time: Sat May 18 06:22:51 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
