Home » Eclipse Projects » EclipseLink » lazy loading problem
lazy loading problem [message #755294] Mon, 07 November 2011 18:39
George Castrey is currently offline George Castrey
While trying to do some tests on lazy loading, to check if i'm understanding it well, i got totally confused.
Here's the entities i'm using on my test:
@Entity
public class Family {
	@Id
	@SequenceGenerator(name="Family_SEQ")
	@GeneratedValue(strategy=GenerationType.SEQUENCE, generator="Family_SEQ")
	private int id;
	@OneToMany(mappedBy="family", fetch=FetchType.LAZY)
	private Set<Person> members;
	//getters & setters
	public String toString(){
		String s="";
		for(Person p:getMembers()){
			s+=p.getFirstName();
		return s;
@Entity
public class Person implements Comparable<Person>{
	@Id
	@SequenceGenerator(name="Person_SEQ")
	@GeneratedValue(strategy=GenerationType.SEQUENCE, generator="Person_SEQ")
	private int id;
	private String firstName;
	private String lastName;
	@ManyToOne
	private Family family;
	//getters &setters
this is my main method :
		factory = Persistence.createEntityManagerFactory(PERSISTENCE_UNIT_NAME);
		em = factory.createEntityManager();
		Query q = em.createQuery("select f from Family f");
		List<Family> families= q.getResultList();
		em.clear();
		em.close();
		factory.close();
		for(Family f:families){
			System.out.println(f);
What i understood from lazy loading, is that if an attribute is marked to be fetched lazily, and doesn't get accessed while it's managed, it won't be loaded in memory and any attempt to access it later won't work. Now what confuses me is that the test described above doesn't have any problem when accessing the lazy members attribute through the detached Family list, even after closing the EM and the EMF ! ... Is that normal? Am-i miss-understanding the lazy loading concept?
Note : I'm using a J2SE environment with an embedded DB.
Thanks in Advance
George
Previous Topic:Compare two EntityManagerFactories for having PersistenceUnits with identical connection attributes
Next Topic:Strange cache behaviour after clear
Current Time: Tue May 21 14:34:32 EDT 2013
Powered by FUDForum. Page generated in 0.01680 seconds
