| Eclipse Code Recommenders 0.4 is out! [message #755188] |
Mon, 07 November 2011 11:08 |
Marcel Bruch Messages: 188 Registered: July 2009 |
we are happy to announce that 0.4 is now available on the Eclipse Marketplace!
Important note: Server URLs have changed. If you have any previous version installed, you have to reset your preferences manually before first use! Therefore, go to Eclipse Preferences » Code Recommenders » [Usage Data Collector | Extdoc | Code Search] and reset the URL from whatever old IP/name used before by pressing the "Restore Defaults" button.
The server URL will then change to an URL starting with "http://recommenders1.st.informatik.tu-darmstadt.de/<service-base-url>".
Most changes for this release happend under the surface. This is a maintenance release. This drop also includes a first version of the Team Server (installable as Extension to your running Eclipse IDE). However, this code is pretty rough on it's edges... More details will follow on the weekend blog-post.
Please let us know if you experience any problem with this drop immediately.
Thanks!
tw: @MarcelBruch
tw: @Recommenders
[Updated on: Mon, 07 November 2011 11:20] Report message to a moderator
FUDForum. Page generated in 0.01907 seconds
