Home » Eclipse Projects » WindowBuilder » Problem installing WBpro3.7(Problem installing WBpro3.7)
Problem installing WBpro3.7 [message #755041] Mon, 07 November 2011 02:23 Go to next message
loicus is currently offline loicus
Dear experts,
I am habing troubles installing WBpro on eclipse 3.7 (indigo),
The error seems to be a timeout error on the google dl repository...
Is there anybody else experiencing the same issue?
Is there any known fix?
Thanks in advance,
Loic
[Updated on: Mon, 07 November 2011 02:24]
Report message to a moderator
Re: Problem installing WBpro3.7 [message #755119 is a reply to message #755041] Mon, 07 November 2011 08:14 Go to previous message
Eric Clayberg is currently offline Eric Clayberg
It looks like you are having a local communication failure or firewall issue.
The Google WB repository is just fine.
You should restart Eclipse and try it again. You can also try turning off any firewall you are using.
Previous Topic:Building aTabFolder
Next Topic:WindowsBuilder Javafx2.0
Current Time: Tue May 21 12:28:53 EDT 2013
Powered by FUDForum. Page generated in 0.01712 seconds
