Home » Eclipse Projects » XML Schema Definition (XSD) » xsd schema
xsd schema [message #75486] Mon, 08 September 2008 03:06 Go to next message
gitanjali punj is currently offline gitanjali punj
Member
hi,
Earlier you replied that for xml instance to xsd schema
conversion api refer the web tools for that. Could you be
more specific which api in webtools does this.
Re: xsd schema [message #75503 is a reply to message #75486] Mon, 08 September 2008 08:27 Go to previous message
Ed Merks is currently offline Ed Merks
--------------010201060708050204080705
Gitanjali,
No, because I don't know any of the details. This is the newsgroup
specifically for the XSD model. The source editor and all other fancy
stuff are provided by web tools so that will be the place to ask about
them. Of course a quick Google search of the Eclipse website can turn
up information faster than newsgroup questions:
< http://www.google.com/cse?cx=017941334893793413703%3Asqfrdtd 112s&q=generate+schema+from+XML&sa=Search>
It seems to me unlikely that any such tool will produce an ideal result
and will be useful beyond acting as a starting point for manual
designing an appropriate schema...
Gitanjali Punj wrote:
> hi,
> Earlier you replied that for xml instance to xsd schema conversion api
> refer the web tools for that. Could you be more specific which api in
> webtools does this.
<html>
<head>
http-equiv="Content-Type">
</head>
Gitanjali,<br>
<br>
Re: xsd schema [message #603269 is a reply to message #75486] Mon, 08 September 2008 08:27 Go to previous message
Gitanjali,
> hi,
> webtools does this.
<html>
<head>
</head>
Gitanjali,<br>
<br>
Previous Topic:xsd schema
Next Topic:xsd schema
Current Time: Sat May 18 07:04:44 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
