Home » Eclipse Projects » Web Tools Project (WTP) » JSDT - Rhino Integration Questions(documentation of Rhino JSDT features?)
JSDT - Rhino Integration Questions [message #754874] Fri, 04 November 2011 13:21 Go to next message
Shaun  is currently offline Shaun
I've started playing around with the Rhino JSDT integration and I have a couple questions. I can't seem to find much if any documentation on it, so I'll ask here and perhaps someone could point me in the right direction.
1) Why can you only launch the Rhino runtime in debug only mode? Why not allow Rhino as a run configuration?
2) When I run the Rhino debug my breakpoints are not hit, the script runs all of the way through and then hangs?!? I've set the breakpoints in the JS editor, is there something I'm missing?
Any help would be appreciated.
Re: JSDT - Rhino Integration Questions [message #754877 is a reply to message #754874] Fri, 04 November 2011 13:29 Go to previous message
I found this:
http :// wiki.eclipse.org/JSDT/Debug/Rhino/Local_Rhino_Debugging
I think that will help with item #2, but I am still not sure about #1
Previous Topic:Can the Formatter remove trailing whitespace in comments?
Next Topic:Re: JSP taglib autocompletition
Current Time: Sun May 19 14:58:53 EDT 2013
Powered by FUDForum. Page generated in 0.01860 seconds
