Home » Eclipse Projects » Maven Integration (M2E) » M2E Plugin does not has Enable Maven Feature on Dynamic Web Project
M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754158] Tue, 01 November 2011 01:31 Go to next message
peterwkc  is currently offline peterwkc
Hello to all,
I have tried to uninstall the M2E plugin from eclipse using the Help -> About Eclipse -> Installation Details but when i click on the it shows unable to install because other project is using it.
I need to uninstall this because i need to have enable maven feature in dynamic web project. Currently, when i clicks the project properties for dynamci web project, it does not have any enable maven feature.
I have install M2E but not M2E extras.
Please advise.
Thanks.
Re: M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754187 is a reply to message #754158] Tue, 01 November 2011 05:40 Go to previous messageGo to next message
I would like to have maven support in the dynamic web project but there is no enable maven option available when i right click the project.
Please help.
Thanks.
Re: M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754325 is a reply to message #754187] Wed, 02 November 2011 02:52 Go to previous messageGo to next message
Please help because this is very urgent because I need to do development for my assignment.
Re: M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754556 is a reply to message #754325] Thu, 03 November 2011 05:33 Go to previous messageGo to next message
There is no Maven options -> Enable Maven dependency management when I click the project.
Re: M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754725 is a reply to message #754556] Thu, 03 November 2011 23:15 Go to previous messageGo to next message
Please help.
Re: M2E Plugin does not has Enable Maven Feature on Dynamic Web Project [message #754726 is a reply to message #754725] Thu, 03 November 2011 23:58 Go to previous message
Problem solved with new clean installation. There are several type maven integration for eclipse from eclipse.org and sonartype.
[Updated on: Fri, 04 November 2011 05:28]
Report message to a moderator
Previous Topic:Multi module projects not working properly
Next Topic:m2e + Spring DM Server Tools error
Current Time: Wed May 22 11:15:26 EDT 2013
Powered by FUDForum. Page generated in 0.01806 seconds
