Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Win7 taskbar grouping
Win7 taskbar grouping [message #754720] Thu, 03 November 2011 21:59 Go to next message
Leung Wang Hei is currently offline Leung Wang Hei
Member
Hi all,
It seems that all java apps are put under the same taskbar group in
Win7, which as stated by some online Win7 doc, are considered as
"similar application".
Is it possible to customize this grouping behaviour (add some Win appId
or something)? Or at least make it consider different jar as NOT similar?
Hei
Re: Win7 taskbar grouping [message #761350 is a reply to message #754720] Tue, 06 December 2011 05:36 Go to previous message
Member
Win7 uses applicationId for the grouping and according to this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294827
(comment #4 and comment #8)
Display.setAppName() should have set the application id in the first time.
With Eclipse 3.7, I try to call Display.setAppName() before
PlatformUI.createDisplay() like the below. Still, all shells dumped to
one taskbar icon:
Display.setAppName(id); // id is ready from a file and different for
every session
Display display = PlatformUI.createDisplay();
Any help is appreciated?
On 11/4/2011 9:59 AM, Leung Wang Hei wrote:
> Hi all,
> Hei
Previous Topic:Unable to hide icon in dock for SWT bundled application
Next Topic:Composite is slow to draw
Current Time: Thu May 23 20:50:29 EDT 2013
Powered by FUDForum. Page generated in 0.04199 seconds
