Home » Eclipse Projects » XML Schema Definition (XSD) » xsd schema import
xsd schema import [message #75451] Fri, 05 September 2008 03:28 Go to next message
gitanjali punj is currently offline gitanjali punj
Member
hi,
does eclipse provide any api's for converting an xml file directly into
its xsd schema
Re: xsd schema import [message #75469 is a reply to message #75451] Fri, 05 September 2008 08:02 Go to previous message
Ed Merks is currently offline Ed Merks
Gitanjali,
The Web Tools project might have such a thing. I.e., deducing a schema
from an instance file, if that's what you mean.
Gitanjali Punj wrote:
> hi,
> into its xsd schema
Re: xsd schema import [message #603262 is a reply to message #75451] Fri, 05 September 2008 08:02 Go to previous message
Gitanjali,
> hi,
> into its xsd schema
Previous Topic:xsd schema import
Next Topic:xsd schema
Current Time: Sun May 19 22:06:59 EDT 2013
Powered by FUDForum. Page generated in 0.01829 seconds
