| Buckminster build does not provide sufficient information to identify missing dependencies [message #754429] |
Wed, 02 November 2011 10:12  |
Matthew Webber Messages: 180 Registered: December 2010 |
I'm performing a create#product action (headless buckminster, but it's the same in the IDE), and it's failing with:
ERROR: org.eclipse.core.runtime.CoreException: /scratch/jenkins_workspace/GDA_trunk.beamline_i24/bm_workspace/features/uk.ac.gda.client.mx.site/build/product.ant:31: Java returned: 13
There is no further information as to what the problem is, even with log level DEBUG.
If the run a PDE build instead, I get this error:
generateScript:
[eclipse.buildScript] Some inter-plug-in dependencies have not been satisfied.
[eclipse.buildScript] Bundle uk.ac.gda.px:
[eclipse.buildScript] Missing required plug-in uk.ac.gda.swingclient_1.0.0.
[eclipse.buildScript] Bundle uk.ac.gda.devices.irelec:
[eclipse.buildScript] Missing required plug-in uk.ac.gda.px_1.0.0.
[eclipse.buildScript] Bundle uk.ac.gda.client.mx:
[eclipse.buildScript] Missing required plug-in uk.ac.gda.devices.irelec_1.0.0.
That tells me my problem (my product feature is missing a plugin that another plugin requires). Note that this is not a materialization problem (everything I need is in the workspace), the problem is that the product feature defintion is in error.
So, when I use Buckminster build, how do I get the equivalent diagnostic information that PDE build provides? Java returned: 13 doesn't tell me enough.
Matthew
| Re: Buckminster build does not provide sufficient information to identify missing dependencies [message #754522 is a reply to message #754465] |
Wed, 02 November 2011 18:01  |
Thomas Hallgren Messages: 3165 Registered: July 2009 |
Output that ends up in that log is normally related to a misconfiguration. Output from the build should go to the
console and to the ${workspace_root}/.metadata/.log
Missing required plug-ins should be detected (and printed) by the PDE compiler in the build step. Not sure why that gets
cloaked in your case. Perhaps it's due to something in your ant script?
- thomas
On 2011-11-02 16:52, Matthew Webber wrote:
> Further investigation shows that there is some of the diagnostic information I need in
> ~/.eclipse/626335158/configuration/1320234741097.log, which is not an obvious place to look, but anyhow ...
> Normally I guess that log would be in the directory containing my Buckminster install. However, that directory is
> network shared, read-only, so that multiple users can use it simultaneously. Hence the log redirects to ~/.eclipse
> instead, as described in the Eclipse documentation on multi-user installs.
> Matthew
FUDForum. Page generated in 0.01656 seconds
