Home » Eclipse Projects » EclipseLink » Attributes missing in metamodel using IBM JDK
Attributes missing in metamodel using IBM JDK [message #735306] Tue, 11 October 2011 09:22 Go to next message
Jan Vermeulen is currently offline Jan Vermeulen
I have detected a problem with the registration of @ManyToOne attributes in the JPA metamodel when using an IBM JDK. It has been detected (in production applications using EclipseLink JPA 2 with OSGI), that some @ManyToOne attributes sometimes are not represented in the JPA meta-model, although their mapping is perfectly valid, and they are always correctly represented when using a Sun JDK, and they mostly also are so with the IBM JDK.
I have not found any reliable pattern for the failure, except that the missing attributes always are @ManyToOne associations, and as far as I have seen, always are defined as LAZY. We normally use the dynamic weaving option of the OSGI implementation of EclipseLink, but I disabled that option in a test and the problem still persists, so it is not related with weaving.
Since the problem seems to occur on a random basis, I have created a simplified test that demonstrates the problem. It consists of an OSGI bundle with an Activator, a persistence.xml and a few simple entities. The code of the Activator for the bundle loops eternally, creating each time a new EntityManagerFactory to force (re)deploy,
and checks all registered entities for any missing attributes. Whenever a missing attribute is detected, the EclipseLink exception is logged and the loop is interrupted.
If running this code with a Sun JDK (5 or higher), the application never ends as deploy never fails. If running this code with an IBM JDK (5 or higher), the application ends after a random number of loops, as the deploy seems to fail and an attribute is detected to be missing in the JPA meta-model.
Due to this problem, we are unable to reliable run our JPA-based OSGI applications on a WebSphere 6.1. or 7 server.
Does anyone has had the same problem, or does anyone have a clue as to what is wrong ?
begin 644 metamodeltest.zip
M4$L#!!0`"``(`)MZ2S\````````````````K````8V]M+FES96YC:6$N<VAE
M<G!A+FUE=&%M;V1E;'1E<W0O+F-L87-S<&%T:)60P6H",1"&SQ7Z#DONSM9"
MH8?=2BDK5*B*;KV6F`SKM'$2)XGHVU=+I:4'H;?YAV\^AK\:[C>NV*%$\ERK
M`=RH`MEX2]S5ZK4=]>_5\.&Z5QFG8PPZK8_AZB<A)SD4'\2V5L:S*D[+6GGI
M`(VC$!'>;0*G,YOUT0GC>?/V-)VTC\^39E[^Y8@3"FL'%E>Y@TS?ERBP2)JM
M%KM\:0\!R_'MHND/X$Z5_WXH6`3C!4%PFTG0SESNB.,E511S5IW&"Z3/*>1T
MAE?$7W!5_B[P$U!+!PA/PP[DSP```'8!``!02P,$%``(``@`FWI+/P``````
M`````````"D```!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="\N
M<')O:F5C=+V2S4X#(12%UYKX#LWLA;IS0:=)-=UI3*H/<(7K]#;\!9C&QQ>0
MT4PF)BZ,NWL.Y\P'#&+[;O3JC"&2LYONAJV[%5KI%-EAT[T\[Z]ONVU_=2E\
M<">4Z1ZC#.133F?W0E@PV$MG&,5<(V#QB,$#,YC`.(4Z84R"UUC)YZA!FWK!
MIZFX[>.Q"CY3KR-I=?`HBVKR+E?!JNJT+;@P,)2:?$1V4HE)%_(`9Z@%#-];
MR`T(PUC8L6D^-P1?4'[%]0K9`UAZRT?>_2_V((]HX$^@S9FN///2&+"E/\4"
M_Z3'@>QC72ST&OJI,/L]=M&9YD+\>@OS9_<!4$L'""3+05GU````M0(``%!+
M`P04``@`"`";>DL_````````````````10```&-O;2YI<V5N8VEA+G-H97)P
M82YM971A;6]D96QT97-T+RYS971T:6YG<R]O<F<N96-L:7!S92YJ9'0N8V]R
M92YP<F5F<Y6.S6K#,!"$[X6^@R!W8:N4@L&7E@322PKM"ZCRV&S0'R.YT+>O
M>O`YSF59=N9;OL.)HBZNJNY%F7XPW6">U-OQ\TN9KN\?'^"\Y`*=B1E$="CZ
M!RR2XMCBQ$5OE>M4M4M$&R&+!]LR84'4$KU$O!>^_E;\'T=$^^TQ[7U0+1?4
M#V_KG!C&7C_?)D/V8IOOGG9F:CI!VU+`>IX0J\P"CB`3]]*(:[B7+6GEYO@'
M4$L'"(P@4C.M````C`$``%!+`P04``@`"`";>DL_````````````````10``
M`&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+RYS971T:6YG<R]O
M<F<N96-L:7!S92YP9&4N8V]R92YP<F5F<S7)L0Z",!`&X+U)WZ$)>\,A<2!A
M,CH[\`)2?[3FTI8[2GQ\P^"W?LWTKNZ&V1$YZH93/_1G=[E.KFNIM0:!8U'X
M(E@@2`'J=XC&G$:RIG!]Q727_$'8/+X;TE$Z+@]66"/0S#N\8*U1,-?T9/SS
M!U!+!PA"PW8F;P```'L```!02P,$%``(``@`FWI+/P```````````````#4`
M``!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]-151!+4E.1B]-
M04Y)1D535"Y-1I52/6_",!#=(^4_1,S-":C:(:@#11E``D6@=C_L(Q@2.[5-
M2OY]'4)=4%NJKO>^[IT]1RDV9&S\2MH()9-H`/TP>#Y(7E`\/Z,>''IH@24E
M$5,E"$.2"02S)5TAE&2Q5)P*ZX2>OFK*M2H$^Z?,!S_"`![\>,RLJ-$J?6UU
MY0&>=.$F>:N9KM+%9#KV\R6]'80FGAZ)':S+2V4MM)(E29M$L^$JC4_IT[)2
MVL89LCWFKH;2.6"%;$O`2:\;V/$UNPN#$Z!,+F"C7=]WI?>CNFORU!O`/?1[
M87`.C;L=.C-BA:@,0=62C76M"'85CM;=GMYC"'WG\9GTDXHI33=D.ZSQ>"GX
MA1L&:6?NUN2\R=HG;))(4][JW,F^",OS[$1,OB?\M>TMW-W`P;-L'&=?TQ<I
MK$FBJ_\R*="8#.TVB2`,PN`#4$L'"*?GI&Y#`0``WP(``%!+`P04``@`"`";
M>DL_````````````````*P```&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D
M96QT97-T+U)%041-12YT>'2=5L%RW#8,O7O&_X#C[HRM2>WFDE/=Q$F=VI-,
MXTZFO7$E:$6;(E62VO7VZ_M`2K(V7K=N?+$M@L##PP/`M\Y&MC$<'YT./\='
MMXT.I'S9Z`U3"0.E+3Y8NBR-[@+39].O3[6ESKL[+B/%1D7"G9:5Q7^.*FZ=
M#=&KR*3$;&6XI:V.#?UTH^SNUGVR.(G1ZU4?.="V84M]T'8M<:Y^OJ&/[WXM
MCH^N(C4JT(IQ7'%$,*YHD4-7?1FULZ2ZSNA2R=]A\#$`O=;VGCY^OJ"S'/O3
MEP]7RY/CHX0WN):?02-'4;<L+#!9%\ESYSF`*(1']-AP\@LS==JZB@V\*A,;
MUZ\;.=6>6N`2+."E8U\#NMG11AE=G2#'2JQVR;\R6[4+(-K[;#0+=GPT9X:^
M]%:(F3EH79`KR@27G.%72E40/M)(8!)$;G(RM>MQ'8DCDM$*M:$.V;.W./+I
M:JVTZ3V?$#^4W`T5EH-6AXQE8DL23PE(^#F?(;A2Y[)DP"ADK;S\&L`$E/6$
M9M<KKK7E9'E]\><?0/Y5(/M6&2390WJ"H=I9U>J2MJPV@L5U20>N3J=29-)M
M!\6!0C4>S22!6@$Y0%0Z2/953F]P,U`[J39$;8R4,.@0D0D8UDGM61=&B282
MYP,>H)8>DM:I>$1U`:UN5`2](\4K%`',&^>Z0"SL2Y(G5'H&:*3%JD0=(4,4
MWO*6+FW4<0>"U9K]>U7"V4Z:#0Y+IH7G9<6=<3N1(G(H&R[O02O`>UX#.WL`
M97&BH6R!(1)X6M""OD)SO&$8/#V6S,=.3*W$>]V6]2(\PLZX]5JJ.3`JJ<IG
M#65[WW?PL*?-J?HCVVQ+_MV"[43O.854UBF'-W3+(=(BL:G"<+!;GL"EG+S-
MHPMY+#!4\F$N]334/->@!6&","F7EEFK>_>_R]%T*4^</@C\WN3:GI$!P2:(
M/&:-@CH'.2\@SE9!/6>8&%YCJH912.7H-KPY/KI6?^]>F*F!Z:%T)=L#CK[/
MXQ,WRR*W@JY82>EA@Z8G78\3AIQ%9[NR[#U2M*GM]T8'0:?XOG*Q&<12D^^M
M%1:C+*K494D@TWRDQ6NYUNAU(_0GWF9;@K*XV59!)DWNFN&CP`K%OT:9]M-_
MA<D!ZI@:R8-GUY+MVQ7^1S%3XTNOACS4,@JPTR::!$B>FO9P\XG1ZG$@']Q*
M:13]XK9BBW22!3H\/F[[V4^NU+3W$1?N^:$#B#R29R^`<?,CZL[UGK;.WX=.
ME3S4&]D@>^A"YR4*K1+1G=JHAV+6W+0X*UX5KY;IU/EUP=E_P7_UVKJ'HG1M
M"]86Y\6/A\Q<6.MG#V=Q"A7:9V/-[;"$GP<U-[SKU$OMQF3^KWTQ[K>7WLML
MC,:Y$!NQV=N`LD8K$=)Y\9H6'_`@,>S&/GUJGJ;Z>.6L^*$XF_;;*`(429YP
M0W-<0N"5*.8=^U5:4`'M$&KI,'Q->X<J%54:V9@FEO,[KNI]>KM=T[3'L&LA
M69]TGYXXDZYV,A34N$338`*<#>9,;J<<G!.6],*I/%3M9]@'Z./KEF[0-3?2
M-#+`"J-ZB_5;Z]%[7DXR"&RMU[V?'A9(.3TYWGO5LO3!O-DROCQ/9!-_VQ>8
MG\&9#5:I]!$%/"!-)7V7,'_3M9GB0SBE>H=L'V?5GG\\!%(V>6+\=BEM?#!]
M`.B<SF_ZP=?^RZKX!U!+!PA3J>'NZ`0``$`,``!02P,$%``(``@`FWI+/P``
M`````````````#T```!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S
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M7GQ.#PQ/T64C..K$#4B025$9)",T>:R`W!Z_W_;U,SHH>Q*38$SBIB/"N$H!
MI$`+1<E1^I[(@_N8T4/5%9)%J2P(Y4]\N?:ED!1^[U_3Q#_Z2R#<,5ESOTCI
M?V@>=5DTR4^0!F?T8OZX1K<T*[K(FV-@W[NBWZP4ZA>199X+E1.)#<HP:$#6
MKF)]<Q/27OP^BIXDM`B-(PQ:JVMTXB"*DK^6/9=[^^].C<4S1K@6SMH#R)L0
M*G`WB#AG9?M#T:K(D'/DRT,QO?:06A_'](&X8\=^0Y^81K`X[R>X!!X/;T'G
M:",.%C(P.)"7'OI,1M>6.]GML50*NWMJ2"'40)M>0VJUL/A_4!E8MHT\<+S@
MK\LOBQ$EZ%U'3VS7!<[^E%SX))C\`5!+!PCFZ7+UYP$``*8%``!02P,$%``(
M``@`FWI+/P```````````````$X```!C;VTN:7-E;F-I82YS:&5R<&$N;65T
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M)B\Z[GFC,YM.I&1)6Z"ZW4[;_B&!RDCTA$"@BU>$4(E:'1J"`BOC=EKV9\>&
MI3MD#J>D0%W<L<S4"=.UU;E(#/BCMB>P/;X,E]L$JCS?='W*1^)+.MGEI'TY
M[K<IMT(]XY;,^+:3]C2L%5@S%W")4X,&K->PKBP=@Q.>+\=TA+&!(3I9WED?
MS[-MQQAP[;0_Z+O2'&O3L$E@W1V*/IDCG5D[E9!N$'<+;.J6F90S06JCBJ>E
MI:4Q8CE9.NG&&D/8B$:5LJV\(!*?;X=!*(EM.N[!=B;=S&1D.D&;D;[H`N'B
MI6U!W"L@HDHQJA1W"C0O9GI)`TISMXYFM`@$?:?`%%@;6:A"V3W8IV'O;&[+
MTZ/C/A69EE&D5#J(_0IR9B&$!W!`PX,"FY7:N)&1KF<SYVE+&@-S>QTQ$/<-
M%JWYLB?MV_[$,3-MCDBWU[18%!,"[4L&5VYV,>VV6AS$0QI8R#N6IZ'C870(
MZ"/2/S9;IP+1R&(WE@K9*(GRPB[T:.AF$2]+04<O#@O4\KZ\.[9DOZR>A2+K
MVREC4/HTVX='-!P56%'&T!'',<)HL]P*G=M0IMM7I-/`<3RJ88"-NI"KXS$,
M$KHT&VM^(10F!QOA\45S.!=2(9M#$QE9BR&<U/$$3A4".THM16<1E9GN2IF>
MQQ([@Z<T/,FA,H^EXVF<939HHEM:*=.5B5Y;IA*>ZI#HF3LLN3*9HI=&GDV+
M)BP-PV6=6R:B(P%91-E)V$F;$>5G75\(([`UC+(H%^K.RNHXA_,JZ]Z@;_JV
MQ=2Q8T^K>]D3:=58&DWW<W*%D`&G\;/EXR=?Q3H\,-W5UJCI=O@%&UTJ=Q=T
M7,1XP;T.G[+#69_>MBVS$>8@*2GGX7].Q_-X@:Z-FEY_'FD&3*?7X"4=+RNG
M0_FJ]SSV@VJ<5W6\IH9]E95R/#J@6879RS?D_^<S9Y3-7Q_5DK.M'%ENVS(K
M,D]?7&>QHE//1U)A*Q!>LC+HD"R-^O)W@KR&\B>,1HO/V*YE^M"^\Q#-!#S?
MR3"9@T[6M62OK2S<57KF6I0I;`6SSU\5WW7UY:/*M88G@U_!;]7.*82N<U,!
MG6MUGK@+*[CJ!0'<A97\LK*PFE)UW`=X6J/,B)^XKR7EG\J#WZ#^>VP\5;=Y
M"ELN58A-.335[<@ADL.N'`S17W?_#;3V-T^C76`:G6HY(A"KFL39<-4T^@5N
M82@6"`>FP3<WA].G8C4W6X.5K=HD6L,U]=J^6'6X.H=G;B!Y!5O5-E69@[/J
M[)>HGL2J<"!/FD:V`B<O::)>JP]^-?.+LDU\K\Q\,8G=L0"]#`=R>)$N-=]&
MA.Z\(C")+;$0CS6%8SCT8_/MF7U%WDST.L-NPM>XRJ";\"W]5-E4Z1K&>JXM
MY.]!(_\Y-6$_(CC`*1I#$NTL]X.L[4.XS//GI%_EV+^&3MKHP11'\@\<X[?0
MC9]YOLWS;SB,W[G_@_L_B='?M*2@.$+DF.0B%&KW.BX1A`K\A3?P9MZ_*;R%
MM^E7'P;P#MXE,$E$\1[>)ZC7"-('^)"TRT5@"U(?Y:'\>"&PC$.5!!&>7QOQ
MO$,-!6;)(5%T2."3O/RG_P%02P<(XJ=K#$P%``!-"@``4$L#!!0`"``(`)MZ
M2S\```````````````!6````8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E
M;'1E<W0O8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O3&%Z>51E<W1#
M;VYT86EN97(N8VQA<W-]4VU/$T$0?K;T12H(%JQ210'?>(E>\-U@3`B*J3DE
MD=I$OVVO(RRYVR-W6V/Y5WXR\8,_P!]EG%V:>`E=+]F]9^9Y=N9F9N_WGY^_
M`&QBHX:2P$:4)H'*24=*!@D9F:1]B@WE)@CER;##8"?51BI-60UE@=DC^54&
ML=0'P5[OB")30U5@WGE5&NQ3IF2L3F0O)A;GSNQ2EJM4?VR_$A!O!:8Y9&ZD
M-ET9#ZB"TT<(E%1?8"[\EZ*M#1U0MB6P\&&@C4JHJW+%L;>U3HTT'#47:+H3
MWX)CFR<W7`P%[3X?6AE#O"$N11KJN^0LFHQ'A6X*+(7^?E@)RQ?'Q'PG];"3
M[FD;KO*%3'0X7K=KJ<[PV.K*X?;G3X7L#PKX80$_*N#'!?RD@)\6\+,"?BY0
M?:&T,B\%)E;7NIQUA^NI8P(WIW`#2P(S(8_V_2#I4=8Y'5HC3".>F>3)L3UR
MELVAXD[?^T]_SMP7+K*^GPZRB':5C=$\H[AO6R30&M.JUSQM,]S",OC3>55P
M'BW4<([Q)-^6$NJ\3V&:[0N,ZNR9X?>LNTL7T1CY+3_':YYP"4UV7/935_S4
M@I]J^:FK?NJ:GUKT4]=]%/]8=IZ\+S,9.!NHK/_`RG?7K5N\5YVS@=NN<TZ`
M.[CK^%6WK[G85K<._`502P<(&7YH0.\!```K!```4$L#!!0`"``(`)MZ2S\`
M``````````````!?````8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E
M<W0O8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O3&%Z>51E<W1#;VYT
M86EN97)#;VYT86EN97(N8VQA<W-]4VU/$T$0?K;T12L(MHA2100%*29>4$0-
MQH2@F)I3$JE-X-OV.L*2NSURMS66?^4G$S_X`_Q1QKF%:#2[7K)S,\_S[,SM
M[-R/G]^^`UC#_1I*`NM1F@0J)QTI&21D9)(.*#:4FR"4IZ,N.]NI-E)IRGX[
M-90%IH[E)QG$4A\&N_UCBDP-58%IBZHTV*-,R5B=RGY,+,YMV*,L5ZG^T'DI
M(-X(3'#*W$AM>C(>4@5GCQ`HJ8%`,_Q3HJ,-'5*V*3#[?JB-2JBG<L6YM[1.
MC32<-1>8L3L^!R=%G=SPJ2CH#'C3HH-X37P4:6A@B[.H$?][XC6!=NCOT%]:
M3C#GJ/)6ZE$WW=5%@<I',M&16[=34-W12:$KAUL'^Z[O>>@"'[G`=1?XV`5N
MN,`G+O"I"WPF4'VNM#(O!,96VCW^^FUN4!UCN#..>=P6F`Q9^&Z8]"GKGHU#
M(TPCG@;),\'Q.5@V1XKO<.,_#?>/)'>MOI<.LXAV5)%LWB]]4#1?H.6XA%<\
M66:TB07P87A5<`DMU'"!_8L\F274V8YC@N/+[-49F>3WE)W;*VB<XP7?Y#5-
MN(H9!J[YJ>M^:M9/M?S4#3]UTT_-^:E;/HI_XN*&V2XP&=@8J*Q^Q>(7VZV[
M;*L6;&+)=LX*L(Q[EE^QMFUS%[I5X!=02P<(VK!ANO(!``"@!```4$L#!!0`
M"``(`)MZ2S\```````````````!)````8V]M+FES96YC:6$N<VAE<G!A+FUE
M=&%M;V1E;'1E<W0O8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O5&5S
M="YC;&%S<WU034_;0!!]&_)1H@`A4#[2D@(GX,"*,U6EBB^ELEJIH;EOG%%8
M9*^1O49M_Q6G2CWT!_1'57U>*L$AJBT_[[R9G3?S?O_Y^0O`"=ZT4%,8Q%FJ
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M(_[;*?;``?DUB'VT\(+G13I:0YO8P1+C99[:9%;X[P:_5]&K7.?+58@O&>D0
M`XVC']AX""VVB,U`=K$=VH4""KT*^=<!=X)`53<`_@)02P<(C^ES'X$!``!7
M`@``4$L#!!0`"``(`)MZ2S\```````````````!2````8V]M+FES96YC:6$N
M<VAE<G!A+FUE=&%M;V1E;'1E<W0O8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E
M;'1E<W0O5&5S=$-O;G1A:6YE<BYC;&%S<X52VTX401`]O>Q%5Q#DIJPB%R^`
M#W;`>S`F!B]9LD@BZ[[WSE:PR4RWF>DEP%_Q9.*#'^!'&6N:SAIC1R>9.E.G
MJT_WJ9H?/[]]![")]08J`FN)S:0NR"1:R8R<RNR`4D>%DUT..]8XI0WE#50%
MIH[4L9*I,H=ROW]$B6N@+C#K66WE`>5:I?I,]5/BXL*G/<H+;<VG]AL!L2LP
MP9*%4\;U5#JD&BX>(5#1`X&9SN\CVL;1(>7;`@L?A\;IC'JZT*S]VACKE&/5
M0F#>[SB17\IS"L=&2+8'O&DULO">V(IR-/"'<U&M=+HIL-SY=Q^X=#&BMZ?,
M:=?NFY'45L!'`1\'?!+P:<!G`9\'?"%0?ZF-=J\$QM8W>@+5';Y`$V-8'L<M
M+`I,=G@.'X99G_+N18>G.S;A!BMN,^>!K+K/FMNR\1]#H\'RS9L'=I@G]$Y[
MT3]6'Y:>!5H1[V]Y).YT&RO@*_-;PQ6TT,`E_K[,(ZV@R7$<$YQ?Y:\F,Y.,
M4W[@US`=^#KCC.=F(]Q<A)N/<-<CW(T(MQ#A6A'NYE\<_[[E(#C>YDSZ'*@]
M^(JE<V]W)127YE:]=5^`.[CKU^_Y>'\DN@;\`E!+!PAUB1.&Q0$``(T#``!0
M2P,$%``(``@`FWI+/P```````````````%L```!C;VTN:7-E;F-I82YS:&5R
M<&$N;65T86UO9&5L=&5S="]B:6XO8V]M+VES96YC:6$O;65T86UO9&5L=&5S
M="]497-T0V]N=&%I;F5R0V]N=&%I;F5R+F-L87-SC9-;3Q0Q%,?_7?:BZW(1
M$&41!;R!#U;P'HR)025K%DA@W??N[`F6S+1FIFO$;^63"0]\`#^4\4QW@V3H
M`Y/TM.?7<\DYI_/G[\DI@'6LUE`2>!K91.J,3*253,BIQ/8I=I0YV6&Q98U3
MVE!Z=JBA+#!UI+XK&2MS*/=Z1Q2Y&JH"LYYJ*P\HU2K6/U4O)C;.O-JE--/6
M?&E]$!"?!<8Y9.:4<5T5#ZB"X2<$2KHO,-/^GZ)E'!U2NBDPOS\P3B?4U9GF
MV.^-L4XYCIH)S'F/'_);GB=S7!')5I^=5@(7V\2E*$=]GYR-)MSY:M<%UMJ7
M[`P[+P8R["ASW+%[YF+PC2)X5@3/B^!%$;PL@E=%\+H(W@A4WVJCW3N!L=6U
MKD!YBRNJ8PQ+#=S&HL!DFPUW!TF/TLYP=M-M&_'H%`^0]1$LNZ^:&[YQV0Z=
M;U7]P`[2B#[I/-!"V.Q)WDV!9J"K'WG\[G@3R^`B>%5P#4W4<(7/5_GYE%#G
MU<`XZQ.LY]HD[U/^<5W'](A7>9_Q;#;`;@387(#=#+!;`38?8,T`6[C`^%?)
M1\/R#FO2ZT#E\6_<_>7+71X9@UU76#:&!KB'^_[^@9</SX(^`OX!4$L'"!2+
MLQG+`0```@0``%!+`P04``@`"`";>DL_````````````````,0```&-O;2YI
M<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+V)U:6QD+G!R;W!E<G1I97,K
MSB\M2D[5TU.P52@N2M;GY<HO+2DH+0$+)&7F`06`I%YF7G).:4IJ,5#0US7$
M4=?3STU?)X:72P$5Z/%R`0!02P<(TEM@^S\```!0````4$L#!!0`"``(`)MZ
M2S\````````````````\````8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E
M;'1E<W0O;&%U;F-H+TUE=&%M;V1E;%1E<W0N;&%U;F-H[5G=;^(X$'\_Z?Z'
MB-OC:7&@7*M5NUR+"KO74[]$:5]6I\@DT^#6L;.V`ZU6^[_?.`DAI2%+[^.A
M%2]@3V8\'[^923+Y>/@0<6<&2C,I>HT.:3<<$+X,F`A[C>OQI]:'AJ,-%0'E
M4D"O(63C\/>??_K(:2+\Z;$4MRQ,%#4H[IC'&#FD"@GXG,4:2!P`21@9?DV8
MD`^GJ0RHACU@(B4'*OK&*#9)##CW\-AKT#@&$1"J0MUP9I0G>*!1"33<&IG$
MR`@M\/M!4`C=4JXWD[JAG`740)6H1A$1KDCB>08OT+B0J&%&?_U[6-KUY?SB
M?/A7G6$^TE06V(H05"M)N4^EG^)02+W[-I?J7L?4!X]+_[M+(C`4?:4NB7D2
M,J'=5;1\J<`]0[9(!L#'H$V=K0'<TH0;SP;3PS11IL)D)LP:L53"XS`#7LC]
M5J>/"9\G`5S$UD_*-XU/V<D`)DF8NDFT3%06&FJD\M@2I8H<YGGRDLO!\"H5
M/)7R/HD'3(&/XO]:?001"",+&YK<'#RISN;71)H#+-%LL:S3;)\6:WZI5+$9
M1<CL_[`9FH/F+YVN_6D?6!VZPIEU7)B6AC*!!CE!$G.&EH/.5:1EDRV?B_L+
M02=W,Q=JTB@^>.:H)1;.%IN2PP4M<WK)4G:\H*+SQ?HP78:YYM3&;-$N;*'*
MG[(9.`$8#,8(J[UTELVTDKZ8FFGIJNO+B#"-AC)*-&9+3`GF>`C&713<'9W1
M!Q);5[5!QB(/=DB;=,ALI]UIM_?:W4YGMTWNJ"H=7F-Z9HUMP"=!'MHU65<@
M,49FDOO:S!5L<5N+VY.64$*/"L/5$L,.V<DP[.RT]UKJPUYW=XOB*T!11UL,
M7SF&Y9OJ%L17"N(=LD+VNK#%\@UA.0<Z0S^WF+X!3*4.V1;(-P#D%L/_"L-\
MHO%_A"D_>FV8W-57\[4L=>_X&XXO[@*33T)L,_]S-/2.+\['_9/SX:AR>%+#
M[Z[R,6%`"<KS4)1G+E<I1"JX.;,A<8\'QRV$^==/,D&RG079[3]RX7)T\7G4
M/_/ZH\_79\/S\57A1DMJY]VWK)JPY7UW6O,286X)-H.7)+M#HN!+DN!(0#BU
MY)O.IYZ:=W5Q/3H>>I?]\1\>FGIS,E@3Z'Q*90=^$["364ZUMMWB4LD9"V#3
M^=13]3>5@1DLF%DH,%_[<=RS;<II#=([@Y!7T\0$<BYZV4RH2+*<X5;1"*RE
M!!ZP&=GZU;VR$:L/#5-,W/<O>,JH&R':0(6`=4(-!,1_T9S5RN8-IQ#IDFZ=
M.CV5<T\#QY*#P)."/VZJ+$LA;X(ISD%7@UX=AJ.\9>RGX5\;.-MK"M;\_R51
MKE&SX,3;4R3%T<Z^]?7]L]'7QMKQ]?PEEE;RTIAB+\'FHB:/+_?=)FZ-P^GE
M5F?_1]\JC**^3="-/U,D&@:9UNR30%\!W32#EM/_U22J>&R(%C-_`]H<[2Z"
MDAWO5GSN0?K?4$L'"(=.W49-!```/AH``%!+`P04``@`"`";>DL_````````
M````````/0```&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+W-R
M8R]-151!+4E.1B]P97)S:7-T96YC92YX;6RME,&.VC`0AL^MU'=(<X\-[2V%
M2"VPARH5J]VMU!N:V-/@K>-$MI-`G[YV2$.@8K7L-@<49N;_/,/\9E:A-L)8
M5`R#72&5F8=;:ZN8TD=H@)A:$586U*6H,G14';Y[&_1/IXMW1@S:MFU)^Y&4
M.J<?)I,I_?$MO6=;+"`2RE@XDQL1FRZ;E@RL*-5S>PA&[YOI9D)VAH_`C<]Z
MVI1,PL3'9R-!5"MA`P4%SD.+QH:!U:`,,-]!9/>5B]^M[M??[Q:K3;I>?$X/
M#$_192,XZL0-2)!)41DD(S1YK(#<'K_?]O4S.BA[$I-@3.*F(\*X2@&D0`M%
MR5'ZGLB#^YC10]45DD6I+`CE3WRY]J60%'[O7]/$/_I+(-PQ67._2.E_:!YU
M633)3Y`&9_1B_KA&MS0KNLB;8V#?NZ+?K!3J%Y%EG@N5$XD-RC!H0-:N8GUS
M$])>_#Z*GB2T"(TC#%JK:W3B((J2OY8]EWO[[TZ-Q3-&N!;.V@/(FQ`J<#>(
M.&=E^T/1JLB0<^3+0S&]]I!:'\?T@;ACQWY#GYA&L#CO)[@$'@]O0>=H(PX6
M,C`XD)<>^DQ&UY8[V>VQ5`J[>VI((=1`FUY#:K6P^']0&5BVC3QPO."ORR^+
M$27H74=/;-<%SOZ47/@DF/P!4$L'".;I<O7G`0``I@4``%!+`P04``@`"`";
M>DL_````````````````30```&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D
M96QT97-T+W-R8R]C;VTO:7-E;F-I82]M971A;6]D96QT97-T+T%C=&EV871O
M<BYJ879AG5=1;]LV$'YV@/R'6UXF-9E2=-A+O&Q-UW1HEJP%DJW87@9:.EEL
M*%(@*;O>VO^^.Y*2E<1MMP*)%8O'CW???7>\=**\%4N$TK2%=*A+*8H6O6A-
MA<JC\_/]O?T]V7;&>G@K5J)00B\+B[7"TA<O)*IJ_@F#*U/)6J*]#_.NZ-`Z
MZ3P=B<6Y]M)OKH0F5^P+47IC-_-/V+_>_OTILS&0=,#-IL.I(\8N"^.6LJBM
M:'%M[&WQK->5PK/2RY4@+^:?M_W):(_O(D_'CQ[M[\$CN&FD`S&`0(6MT<Y;
M082"@,Z:A<(6UM(W\)2BWMR85QI!>&_EHF>C=8,:>B?U$H2&E\^NX.+Y+T7`
M?NFA$0X62!85>B(9*\BD9MBJIS.-!M%U2I:"_W8)YKQ4LG-X*?4M7+P^@R?Q
M^%?7/[_,CP*P;X0'9UK\B$^\Y&7+(5@$;3Q8["R2:-@#<L`W&*"9]F\"[Q%8
M*-^8?MFP@;30DG?L$5%$R:HI`+6!E5"R.J)@*[;:A".$6HN-(VE:&XTFYP7@
M*4MPW6LF:8+1&L>[A'(FX-$CQ,Q^WJ$T\DJTKF)<M:',$@Z?J*2@9$%'1*#5
MM&3#_EI(U5L\`GQ78N<C>;S02A<=&HE+'(18V(TIN\X9JKB0I^@X9;86EA_)
M'T=Y/IINK["6&H/EY=F??\0(WK#CMA6*XNT=!D^JC1:M+&&-8L4>F2YHP]1A
ME1,/I&T2(A$JAJ6)3&+R*`1RI9*.::ABG`DI$3WJV7FI%*0"I'B(;^DYS5$K
M2K!.0@:22Q/V;QKN0162KI59@S*F<X!,.<=T!*5%\I&B0%%2!DF&E'*-:]C5
M.L`;3E2)D%G,*^R4V20IDLME@^5M2!%Y:W')W<*29\A(DN3-.>;D/TQE`6](
M<KA",GBXS*$.%3F4%,+Y9=((4T86RBR7G+Y$'D?*KR6IVMJ^H[T/13GF'";M
M[3=-[`8ZOP47,CF&<`(WU+HAXP,6PJ6%37Z4R*9%;EN"0"UDU&'B>LQN&5<<
M<5,3,7228T)Y4QY%>F?_%P&-F\;>TSL.HE<QRT]`$<O*L20G14(9=[Q>$#&M
M(+4\H<9AI=#>#;HN!V1W$I`OQ=^;_QBO(M-=07/,N[&^#/0!3%Z,-2`K%"P'
M,J/*!UD/G0:,IMHV9=E;BE6'VK_3/^B&XO<+XYNI@&JPO=;,J>=+*=18$,W8
M,2'[CO<V<MEP/@*+DPL$HMY15XY[3JRF]))]<\7G#AHOL,^=%,^H?2@O2ZR;
M%G3?+N@[93?TA%3&+G:XZ`L1U0;&V)W81?7NJF2CQ;9'[[RS)N0]%3W=7!8N
M".]WM"WVBBZ<[*W0Q6KX^G28FFB"RGD7_Q[O[W7]@N*"4E&.8)PGMAW7P;U1
M`_[A"6*6]JV,K*BA"NNS.V-&$!8]<_+<FK6#\[&WT/[9C-H(2#B%QW/^MFXD
M=87,VQ[SN#Z[WE#W:`O3^Z*S9*UT=O`\\!A21[(LB@*RDJY`RL,)'!QFAX<R
M/SS(#_*`.=O9<>OT/*6$*14-PX>GE_'DV?'QI!_'WK@#*MIN\2:S7A%N`=RU
M*SM@UP<7Q_-"KX\-_2/-GBJ,EUH,,JMYGMWV$D[>B!4ZL8CCB.N,KNXU_RBF
MK9!2('1VMAT_O__QAZ%/G`RD%4OT5\.HFN7\]3RYE^5YA(DX8=R.3M+VB,/F
M%S3Z,GK<_!S)<0HR6#/$D(`0AES2I("L+4\ZXVI9FQ7).H4^6!(OV3"\TW\&
MU\$\"T;!W[04X-^_AW'A5YJ.R8VR$?;,9X]S.#V%K__Z>@AC-F,!2]WC?'BS
M#>-L(#.[!Y</QA_"\P-0PZ`Q(-N*?]0WATAS(H_L.\>Q$#$!`U5`W+"C(C"F
MQ#E2V/;T!:GO=IX\H`LY3%OI5*9KT.Q7L0C&S*4LE\HX0DL`_,D?'W94O>G^
M5]$3!/W\"U!+!P@'2Q5<H04``,H-``!02P,$%``(``@`FWI+/P``````````
M`````%4```!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]S<F,O
M8V]M+VES96YC:6$O;65T86UO9&5L=&5S="],87IY5&5S=$-O;G1A:6YE<BYJ
M879AG9%+3\,P#(#/J]3_X./8H=-XHVE2$2\5#7%@3(*;UWI;1II4B3M1$/^=
MI&43<.BA4A(IB;_8_E)@^H8K@E3GD;"D4H%13HRYSD@R61Z'01B(O-"&88-;
MC(2.GL@(E.(#%Y+^W[]'!1DK++NW*+I1++@:MT3<$J?K65506]`=*3+(E,U1
MEJV12=9V^X"JFNE'U50]'`S"``;0%`F\1G8>%*-0%J:7KR]@:$G&DQ98P\SI
M`*B1>HFQY+4V<(\*YF1R*B4IZ&]01=O=-MY)=8(//.7G,`SB)FD8%.5"BA12
MB=8EQ8_*9[EJJB`#KA5).2FV\-LZ?(9!KS!BZZ2`963WQ%(HE""U6H&M0^>^
M<ZV>DVN8P&CJ>NZY$2>97_\J=2>)8EKYC%DMIQ?O9?67_H\F^Y^*O!O73*\6
M(G]J'HVA`W78B3KJ1!UWHDXZ4:>=J+-.U'DGZL)37V'P#5!+!P@J9-NJ6@$`
M``($``!02P,$%``(``@`FWI+/P```````````````%X```!C;VTN:7-E;F-I
M82YS:&5R<&$N;65T86UO9&5L=&5S="]S<F,O8V]M+VES96YC:6$O;65T86UO
M9&5L=&5S="],87IY5&5S=$-O;G1A:6YE<D-O;G1A:6YE<BYJ879AK9'+;L(P
M$$771,H_S)*R,*+O"B&EZDM45%V4(K6[(1G`U+$C>T!-J_Y[[42@PH)N(B66
MDYE[/+ZWP/0#YP2IR85TI%.)(B?&W&2DF!SWXRB.9%X8R[#$-0IIQ`M9B4I^
MX531?OU3%&2==.Q9).XT2R[[!SKNB=/%N"SH4-,#:;+(E$U0K0YV#K-#U2?4
MY=@\ZWKJ;J<31]"!>DC@!;+W03-*[6!T_?X&EF9D@](!&QA[.V[J.ME*64DD
M.U*S?Y4`E:1:$ESQPEAX1`T3LCFM%&EH+U&+]>8SV<3AHSD*JO!VXRBIQXVC
M8C55,H54H?.'XE>Y,]]V`]X-13EI=O`W./B.HU9AY=K["HZ1/6LF-2I01L_!
M5:V38)[1K\-;&$!OY&UK^2<99F'=3<7_&6JF>3@QJ_QM)5N_V[,0\V`;M@@F
M^5NU=F8&M7^+7A\:X1PWQ#EIB'/:$.>L(<YY0YR+ACB7#7&N`N<GCGX!4$L'
M"'2^#>!K`0``YP0``%!+`P04``@`"`";>DL_````````````````2````&-O
M;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+W-R8R]C;VTO:7-E;F-I
M82]M971A;6]D96QT97-T+U1E<W0N:F%V87U0RTX#,0P\-U+^P4?80RK.%=(>
M0-4B;H7>W5UW<<E+B;?B(?Z=9$LEX%`IL93,>.R9B/TKC@1]<(8S^9[1.!)T
M82`KE&6EE5;L8D@"!SRBX6`VE!@M?^#.TG_\S41*F;,4+3+W7EC>5Q<8:_*4
M4&C8HIWH$K,;YEG+IM$*&CA)PSXDJ'M"G%(,F69L+BU.\E+0!_2PI>1HLN3A
MZH#>',_/]NRY^+^N7?4NM6I/ZEK%:6>YA]YBSO!4YY3]+#GRDN%W#O"IU2(F
M/A8OD`6E=.W9HP4;_`AYIFZKG>"?NSNXA9O'XF=13ML-M?Y-HOQT7FBD!#S\
M$#>2N&AY=#6H+ZV^`5!+!PB0?@1[`@$``+X!``!02P,$%``(``@`FWI+/P``
M`````````````%$```!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S
M="]S<F,O8V]M+VES96YC:6$O;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R
M+FIA=F%]D6]+PS`0QE^OT.]P+W4O.N9_&4)%QY@H@LZ]O[6W+3.]E.0ZG.)W
M-VF9J&`@"5Q^=[E[GM18O.**H#!5IAQQH3"K2+`R)6DA)Z,T21-5U<8*;'"+
MF3+9,UF%6KWC0M-?_I;59)URXM^B;,RB9#>*9$R(R:)0.4?=4"QS6L;H`_)N
M9AZY&VC0[Z<)]*'K#[)&\1)94+&#\?5D_`26EF1#J0,Q,/-2`=J:]LBQD;6Q
M<(<,<[(5-9H8#C;(V78?YGO#O'F'H2KL09KD7=<TJ9N%5@44&IUK.]QT(Y`%
MKT-312P.?KH)'VG2JZW:>D?`"8HO7RI&#=KP"ER;.@^R#;],;^$*AO=><,^O
M?%J&\[>?_F;*0JO0L6R=Z>7?3OF@E1V^>3B"?]E1A!U'V$F$G4;8682=1]A%
MA%T&]IDF7U!+!P@A8@(`/0$``/`"``!02P,$%``(``@`FWI+/P``````````
M`````%H```!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]S<F,O
M8V]M+VES96YC:6$O;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R0V]N=&%I
M;F5R+FIA=F&5D=M*`S$0AJ^[L.\PE]J++?4L15C14E8406OOI[O3-C4[69)I
M\8#O;G:7EM:+2B`)&?+]<_A38?Z.<X+<E(ERQ+G"I"3!TA2DA9P,XBB.5%D9
M*[#$-2;*)*]D%6KUA5--?]\_DHJL4TY\+DJ&+$H^!P>($3%9%"HFJ%=TB,R*
M0Z]/R)]C\\QM0[UN-XZ@"VU]D`6*'Y$%%3L8WHZ&+V!I1K:6.A`#8S_J70N0
M;:2-1HDC/?M?"M!HFB/%E2R,A0=DF)`M::6)X6B)G*PW8;KQVOM^7*OJW8NC
MM&TXCJK55*L<<HW.[3>WO8#W0E-)+`YV?P2^XZA36;7VKH(3%)]GIA@U:,-S
M<`TZJ:TS_);=PPWT'[UI';_2K*C/_3_9R9:QT+RN7#0N=]*MZS[8ZQ)D-^H/
M((`^":)/@^BS(/H\B+X(HB^#Z*L@^KJF?^+H%U!+!PARVR/23P$``-X#``!0
M2P$"%``4``@`"`";>DL_3\,.Y,\```!V`0``*P``````````````````````
M8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E<W0O+F-L87-S<&%T:%!+
M`0(4`!0`"``(`)MZ2S\DRT%9]0```+4"```I`````````````````"@!``!C
M;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="\N<')O:F5C=%!+`0(4
M`!0`"``(`)MZ2S^,(%(SK0```(P!``!%`````````````````'0"``!C;VTN
M:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="\N<V5T=&EN9W,O;W)G+F5C
M;&EP<V4N:F1T+F-O<F4N<')E9G-02P$"%``4``@`"`";>DL_0L-V)F\```![
M````10````````````````"4`P``8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M
M;V1E;'1E<W0O+G-E='1I;F=S+V]R9RYE8VQI<'-E+G!D92YC;W)E+G!R969S
M4$L!`A0`%``(``@`FWI+/Z?GI&Y#`0``WP(``#4`````````````````=@0`
M`&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+TU%5$$M24Y&+TU!
M3DE&15-4+DU&4$L!`A0`%``(``@`FWI+/U.IX>[H!```0`P``"L`````````
M````````'`8``&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+U)%
M041-12YT>'102P$"%``4``@`"`";>DL_YNER]><!``"F!0``/0``````````
M``````!="P``8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E<W0O8FEN
M+TU%5$$M24Y&+W!E<G-I<W1E;F-E+GAM;%!+`0(4`!0`"``(`)MZ2S_BIVL,
M3`4``$T*``!.`````````````````*\-``!C;VTN:7-E;F-I82YS:&5R<&$N
M;65T86UO9&5L=&5S="]B:6XO8V]M+VES96YC:6$O;65T86UO9&5L=&5S="]!
M8W1I=F%T;W(N8VQA<W-02P$"%``4``@`"`";>DL_&7YH0.\!```K!```5@``
M``````````````!W$P``8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E
M86EN97(N8VQA<W-02P$"%``4``@`"`";>DL_VK!ANO(!``"@!```7P``````
M``````````#J%0``8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E<W0O
M8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O3&%Z>51E<W1#;VYT86EN
M97)#;VYT86EN97(N8VQA<W-02P$"%``4``@`"`";>DL_C^ES'X$!``!7`@``
M20````````````````!I&```8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E
M;'1E<W0O8FEN+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O5&5S="YC;&%S
M<U!+`0(4`!0`"``(`)MZ2S]UB1.&Q0$``(T#``!2`````````````````&$:
M``!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]B:6XO8V]M+VES
M96YC:6$O;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R+F-L87-S4$L!`A0`
M%``(``@`FWI+/Q2+LQG+`0```@0``%L`````````````````IAP``&-O;2YI
M<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+V)I;B]C;VTO:7-E;F-I82]M
M971A;6]D96QT97-T+U1E<W1#;VYT86EN97)#;VYT86EN97(N8VQA<W-02P$"
M%``4``@`"`";>DL_TEM@^S\```!0````,0````````````````#Z'@``8V]M
M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E;'1E<W0O8G5I;&0N<')O<&5R=&EE
M<U!+`0(4`!0`"``(`)MZ2S^'3MU&300``#X:```\`````````````````)@?
M``!C;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]L875N8V@O365T
M86UO9&5L5&5S="YL875N8VA02P$"%``4``@`"`";>DL_YNER]><!``"F!0``
M/0````````````````!/)```8V]M+FES96YC:6$N<VAE<G!A+FUE=&%M;V1E
M;'1E<W0O<W)C+TU%5$$M24Y&+W!E<G-I<W1E;F-E+GAM;%!+`0(4`!0`"``(
M`)MZ2S\'2Q5<H04``,H-``!-`````````````````*$F``!C;VTN:7-E;F-I
M9&5L=&5S="]!8W1I=F%T;W(N:F%V85!+`0(4`!0`"``(`)MZ2S\J9-NJ6@$`
M``($``!5`````````````````+TL``!C;VTN:7-E;F-I82YS:&5R<&$N;65T
M86UO9&5L=&5S="]S<F,O8V]M+VES96YC:6$O;65T86UO9&5L=&5S="],87IY
M5&5S=$-O;G1A:6YE<BYJ879A4$L!`A0`%``(``@`FWI+/W2^#>!K`0``YP0`
M`%X`````````````````FBX``&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D
M96QT97-T+W-R8R]C;VTO:7-E;F-I82]M971A;6]D96QT97-T+TQA>GE497-T
M0V]N=&%I;F5R0V]N=&%I;F5R+FIA=F%02P$"%``4``@`"`";>DL_D'X$>P(!
M``"^`0``2`````````````````"1,```8V]M+FES96YC:6$N<VAE<G!A+FUE
M=&%M;V1E;'1E<W0O<W)C+V-O;2]I<V5N8VEA+VUE=&%M;V1E;'1E<W0O5&5S
M="YJ879A4$L!`A0`%``(``@`FWI+/R%B`@`]`0``\`(``%$`````````````
M````"3(``&-O;2YI<V5N8VEA+G-H97)P82YM971A;6]D96QT97-T+W-R8R]C
M;VTO:7-E;F-I82]M971A;6]D96QT97-T+U1E<W1#;VYT86EN97(N:F%V85!+
M`0(4`!0`"``(`)MZ2S]RVR/23P$``-X#``!:`````````````````,4S``!C
M;VTN:7-E;F-I82YS:&5R<&$N;65T86UO9&5L=&5S="]S<F,O8V]M+VES96YC
M:6$O;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R0V]N=&%I;F5R+FIA=F%0
52P4&`````!8`%@`%"@``G#4`````
end
Re: Attributes missing in metamodel using IBM JDK [message #754015 is a reply to message #735306] Mon, 31 October 2011 09:14 Go to previous messageGo to next message
Not much activity here...
We have reported the problem to IBM (as we assume the problem is with the IBM JVM, not with the EclipseLink JPA implementation), but they consider it to be a problem of the EclipseLink implementation.
To further exclude possible sources, I have attached a simplified version of the test code, that does not run in an OSGI platform: just a simple plain java executable. The attached zip contains the contents of a simple Eclipse Java project to run the test. It does not contain the dependent libs, as the zip would exceed the permitted size. It requires the following: eclipselink.jar (EclipseLink JPA implementation version 2.1.3), javax.persistence_2.0.1 (JPA 2 api) and derby.jar (Embedded database). Those are publicly available on internet.
If this simple test (randomly) fails on an IBM JVM, I don't see how anyone can reliably use EclipseLink JPA in a web-application running on WebSphere. And I suppose we're not the only ones using that combination...
M4$L#!!0`"``(`&)K7S\````````````````D````8V]M+FES96YC:6$N;65T
M86UO9&5L=&5S="\N8VQA<W-P871HE5'12L-`$'Q6\!_"O7=S%ZGXD%A$(EBP
M0IOZ6BYW2WKIN0EWE]#^O:DV*()*WV:6F=UA-IWMWVS4H_.FH8P)X"Q"4HTV
M5&5L73Q.;MGL[NHR559ZW\JP'<C%%T,*[A#M#.F,>:=8=!Q^POAWI6IH5#:N
M`E36M!ZAU@&L[$AMA^LP7^:;AY=%<?^TR)?Q3YVA@(ZD!8UE5T%G3DYTL`J2
MM'3Z];DXM!C/DU4^$3#]*Y`UY1AH@/'ID#6T@UJZ,YRU[.4>VF.?/@Q%XB8!
M#@+ZA`O.;_BU$%-^YDZ-KCS\YVFZT'9AM`7I*@P?^C3^_KIW4$L'"$_=D,KP
M````\`$``%!+`P04``@`"`!B:U\_````````````````(@```&-O;2YI<V5N
M8VEA+FUE=&%M;V1E;'1E<W0O+G!R;VIE8W1U4$L.PB`47&OB'1KV@NY<T+K0
M>`'U``@O#4WY!&CC\05*;6KB[LV\F3<#]/Q6?36"\]+H&AWQ`56@N1%2MS5Z
M/F[[$SHWNRVUSG3`PQ4\=]*&J([LAFJFH.%&8>FC33*L(#!E!/0!?*`D[Y,P
M:A3HT%`R3XDM5WT&9(5>@^S%W0)/J,!+M#(M,E.RC6LQ\%Y:#[@3`7/CXL!&
ME@W@E@K1P5P[I&Q?,%D3E/RF%&:N$2/#X*"H)_"_P;1/!;(NGUL.?)^[_M(/
M4$L'"(K*G@''````D0$``%!+`P04``@`"`!B:U\_````````````````/@``
M`&-O;2YI<V5N8VEA+FUE=&%M;V1E;'1E<W0O+G-E='1I;F=S+V]R9RYE8VQI
M<'-E+FID="YC;W)E+G!R969SE9#+:@,A%(;WA;Z#D+W4)*40<-/20DIOB]*]
MH_\,%CW*40-]^SJD76=F(P?U._]E\YI(O-LJ=DJH[6&W/^SOQ,/CI]C>*'5]
M!1M\+I"9,8)!%D6>P,4GTOTY\23_OWR[*FUB]"-F'\!]<)A`TE/PA.?"]S\5
M\Z4&F2'`+5U0#4^H'\'4,7'42MXN)1NU`O>2K`FZ9RC@$RZS,0=O>M8E2@Y#
MF^0<\*W%`:R[+-C4BS)_X&SMR["?"UG)EM38XLFO`#.GKA.E*;V*>G2@ZD??
M78,Y\5(:U.):]FSVW.@O4$L'"*7IE)+>````=0(``%!+`P04``@`"`!B:U\_
M````````````````/@```&-O;2YI<V5N8VEA+FUE=&%M;V1E;'1E<W0O;&%U
M;F-H+TUE=&%M;V1E;%1E<W0@3&%U;F-H97(N;&%U;F-HI5-=3\(P%'TW\3\T
M?;>3%^,#2";.",E@&45C0K*4[HK%KEW:CLB_MXR/`+KX];1TY]YSSKVG;7??
M"XF68*S0JH-;Y!(C4%SG0LT[>$+O+ZXQLHZIG$FMH(.5QMV;\[.V9)7BKSVM
M7L2\,LSY=N16I:_09DZ`2U%:((O<D4VEYR-2<R8';,G"LI2"UTUX36:=\7CH
M_&=6.4!OL.K@&<LSKI5C0H')%"L`HR63E9>8<ET08;U1P8@MP+%"YR`=6#?=
MR.&@-BFL.V$]=)?#K)H3K@V0.$R2Z"Y+H_%HDO:B+`GIPQCO."+ES&HG'AR*
M'VD'UO`U&FS1X!B-=R?J3V3A][!Q&1S9_)]O^IQ$#;Y;36I?;K\YQ4$:9;W1
MD(;]893N(_EA?7!:)Y0#HYC<#E6);2<8,JZOG<D?8^HO5M"_C=$3S,:EQP!=
MD1;RS)N9?CE![*W4F]J[;XR4'(7V)[4D'0VB'LU"2M/O!7<A?7Y>_O\'4$L'
M"("R]@]Q`0``K@,``%!+`P04``@`"`!B:U\_````````````````-@```&-O
M;2YI<V5N8VEA+FUE=&%M;V1E;'1E<W0O<W)C+TU%5$$M24Y&+W!E<G-I<W1E
M;F-E+GAM;*V438^;,!"&SZW4_T"Y8R?MC1*D-LD>JE19[6ZEWJ+!GA)OC4&V
M^<B_KTTH(9%2;5;+`<',O(_G"Y(*M1'&HF(8=(549A'NK:UB2I^A`6)J15A9
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MRHG$!F48-"!K%[&]NPOI(/X81?\EM`B-(XQ:JVMTXB"*TG^;<BGW6]>=SY-G
MC'`MW$:-(#][J,`M+G$#S0['H'61(>?(5\=@>NLAM3Z5Z0UQSX[]=+XPC6!Q
M,51P#3PMWH+.T48<+&1@<"2O//2%C#XM=[*;8ZD4]I^'(850(VU^"ZG5PN+;
MH#*P;!]YX'3`WU??EA-*,&P=/5N[WG#Q+W#F,V/Z%U!+!PA5KBD^V@$``!T%
M``!02P,$%``(``@`8FM?/P```````````````$H```!C;VTN:7-E;F-I82YM
M971A;6]D96QT97-T+W-R8R]C;VTO:7-E;F-I82]M971A;6]D96QT97-T+TUE
M=&%M;V1E;%1E<W0N:F%V89U646_;-A!^=H#\AUM>*B6>7'382^QDR=9T2-:L
M!9)M#\,PT-))8D.1`DG9-=;^]]V1DNRD;@8,B65+/'YW]]UW1[4B?Q`50FZ:
M3#K4N119@UXTID#ET?GYX0'_R:8UUL,'L1*9$KK*+)8*<Y^]D:B*^3,&MZ:0
MI40[?P+S,6O1.ND\.<7L2GOI-[="4S#VC<B]L9OY,_;OM[^?,QM3Z1W<;UH,
M@<R.CP\/X!@6.:V>WPYF]Y3Q8A:>08&-T<Y;032`@-::I<(&UM+7<$&1;N[-
M.XT@O+=RV;'1ND8-G9.Z`J'A^L=;N'G]2Q;\7'NHA8,EDD6!GHC!`A*I&;;H
M<B^-!M&V2N:"?[L>YBI7LG7X5NH'N'E_":^B^W=W/U^GTP#L:^'!F0:_$A,O
M>=EP"A9!&P\66XM4:HZ``O`U!FBFZMM`0@06RM>FJVHVD!8:BHXCD@Z(X)(2
M4!M8"26+*25;L-4FN!!J+3:.!&5M--KQ%X!W68*[3C-).QB-<;Q+*&<"'GV%
MG#G.1Y0NEO8\<DO4KF)NI>D(AW@@KTH**ABT1`9:34LV8)1"JL[B%/!CCJV/
M!/)"(UT,:B2OYR'DPZ'L,NR<H5X)M7H2SKUA:-45&&"Y5M`JX2F`!BB(-8I5
M\$-,&G+)0>:B<^BF0RH./70MT>-(V;3,PB90S#L?<N+&C%[O:^Y=<K5$9=:@
MC&D=("<LE-I,(;=(09(W%#EQ2$(@5(UKV-=PX`W3E",D%M,"6V4VO1B(U;S&
M_"$$KA316W&/6=(0,I(D@3'#3/V71&;P!Q4=5T@&7RZSIH:>&$2-</6VKQ"W
M!EDH4U58##H)F?)C2;JRMFMI[WY9%%A*S1MA9S#\IJ6/LOINX'A(8\H/.A59
M>P6*HE8.3+E;<F+0\?II]-BIZ'&AY#E/$$@XPJ5P/>HF7<QH"1X9_62T%Q29
MA82&1;2+8LSCBB.22V*8PG5<&=X4@?;C_"_`<=,N\FQ,:.2R!-MIS93X6KHH
MN<#?V,*0?,_JKF55$]HT%&EGHD$L/^K"L?*CN/J'W))]%SWC:)RH_^4I^BA]
M4)LEP9@&=-<LZ9[*&%JD5[4+>_M8'&(3>.%P@L[(Y5Z1LM%R.S#V#M&83KA<
MB(Y&J84;POL=;8.=H@F8?!`Z6PVW%\/A2P=QRKOX,SL\:+LEY06Y(O7!HV,*
M_CD\F/3+SE/F.:R,+&A02YW<4=2Z^O,O&EN52X/IA#H%))S!RSG?K6M)HD^\
M[;!?G]QMJ#F:S'0^:VF[5SHY>AVX">7@F9-ED.0T8XG;4S@Z24Y.9'IRE!ZE
M`7.R=ZB4_?<9%4&I:!@NGAY&SY/9;&?DQ/;?`Q5MMW@[+P%9&'2X;U=RQ*$/
M(8[^PCB+,^LK\TR68:G!()V27W3"(.#P0D%&K#!H1#SS7&MT\62^18%LQ=$G
M0KZ3[7O)XH?SH6M/!]*R"OU8]23EVZL^O"1-(TS$">]A,4C:'G'8_(:.#D:/
MFU\C!4Y)!FN&&`H0TI"5-GSB1C5Q!ZS-BJ3:ISY8$B_)\%9'+XUWP3P)1B'>
M?BG`?_H$X\*OHN$P\EK82Y^\3.'L#%[\_6)(8S+A.25UA_/AR3:-RX',Y`E<
M.AA_#M^?Z2CU=-(E5^/9,>J;4Z27$7Y3W'O>AXP)&*@#XH8]'8&Q),Z1PK;>
MEZ2^AWD?`9TW?/@.7IFN0;/?Q"88*]=7.5?&$5H/P%>^T(?^_P502P<(68#X
M?P(%``"B"P``4$L#!!0`"``(`&)K7S\```````````````!!````8V]M+FES
M96YC:6$N;65T86UO9&5L=&5S="]S<F,O8V]M+VES96YC:6$O;65T86UO9&5L
M=&5S="]497-T+FIA=F%]4$U/PS`,/:]2_H./L$,FSA52#Z"IB-N@=Z_UBD>^
ME+@5'^*_DW1,`@Y3$DN.GY_]7L#^%4>"WEO-B5S/J"T)6C^0$4I2JZH<ML%'
M@2/.J-GK'45&PQ^X-U3_J[_I0#%QDLQ&^MX)RWM]`;$E1Q&%A@[-1)>0[;#,
MVJS7JH(UG*CAX".432%,,?A$2VT)#4[RDJL/Z*"C:&DRY.#JB$[/Y[0YJ\X.
M7)>N\C:J:D[LJ@K3WG`/O<&4X*G,R?L9LN0DP6\?X%-5JQ!YSEH@"4KN.K!#
M`\:[$=("[8H<[Y[;.[B%F\>L9Y5OTPXE_G4B_[1.:*0(//P`=Q(Y<SFTQ:@O
M57T#4$L'"`>65`L#`0``P`$``%!+`P04``@`"`!B:U\_````````````````
M2@```&-O;2YI<V5N8VEA+FUE=&%M;V1E;'1E<W0O<W)C+V-O;2]I<V5N8VEA
M+VUE=&%M;V1E;'1E<W0O5&5S=$-O;G1A:6YE<BYJ879A?9%M2\,P$,=?K]#O
M<"]U+S+GLQ2AHF-4%,&'O;^UMRTS34IR'4[QNYNT3%0P)#E(?G>Y_/]IL'S%
M)4%I:B$=Z5*BJ(FQ-A4I)L=9FH0AZ\98AC5N4$@CGLA*5/(=YXJR/_Q--&2=
M=.QO(S'1+'F;13*FI,DB4S5#U5(LLZAB]![U]MD\Z/Y!H^$P36`(?7_@%;(7
MJ1FE=C"YFDX>P=*";"AUP`:>O5B`KJ8+.;:\,A9N4<.,;$VM(@U[:]1BL]OF
M.\N\??NA*JQ1FN1]US1IVKF2)90*G>LZ7/=/(`M>AZ*:-#OXZ29\I,F@L7+C
M'0''R+Y\(34J4$8OP76ILR#;Z)?B!BYA?.<%#_S,BRK$WW[ZDT(S+4/'JG-F
MD'\[Y3>=[/#1!QG\R\81=AAA1Q%V'&$G$78:86<1=AYA%X%]ILD74$L'"#/%
MZA-!`0``#@,``%!+`P04``@`"`!B:U\_````````````````4P```&-O;2YI
M<V5N8VEA+FUE=&%M;V1E;'1E<W0O<W)C+V-O;2]I<V5N8VEA+VUE=&%M;V1E
M;'1E<W0O5&5S=$-O;G1A:6YE<D-O;G1A:6YE<BYJ879AE9'?2\,P$,>?5^C_
M<(^ZA\[Y6XI0T3$FBJ!S[[?VMF6F24FNPRG^[R8M&YL/DY#DR)'/]W+YIL+\
M`^<$N2X384GE`I.2&$M=D&2RG,:1'Z*LM&%8X@H3H9,W,@*E^,*II/3/^6=2
MD;'"LJM&R4"QX'5Z@!B2(H-,Q01E38?(47'H]!G5>JQ?5-M0K]N-(^A">S_P
M`MD]4C$*96%P-QR\@J$9&2^UP!K&[K'W+4"FD38:P9;D['\I0*-I0H8U+[2!
M1U0P(5-2+4G!T1)5LMJDV<9MY_RQ5_G5BZ.L;3B.JGHJ10ZY1&OWF]MNP'DA
MJ23%%G9_!+[CJ%,9L7*N@F5D5V<F%$J06LW!-NC$6Z?5^^@!;J'_Y$SKN)F-
M"A_W_V2GVD@QS?W-1>-R)]NZ[I*]+H%WLY,4`NA^$'T:1)\%T>=!]$40?1E$
M7P71UT'TC:=_XN@74$L'"-%7D?E3`0``#@0``%!+`0(4`!0`"``(`&)K7S]/
MW9#*\````/`!```D``````````````````````!C;VTN:7-E;F-I82YM971A
M;6]D96QT97-T+RYC;&%S<W!A=&A02P$"%``4``@`"`!B:U\_BLJ>`<<```"1
M`0``(@````````````````!"`0``8V]M+FES96YC:6$N;65T86UO9&5L=&5S
M="\N<')O:F5C=%!+`0(4`!0`"``(`&)K7S^EZ922W@```'4"```^````````
M`````````%D"``!C;VTN:7-E;F-I82YM971A;6]D96QT97-T+RYS971T:6YG
M<R]O<F<N96-L:7!S92YJ9'0N8V]R92YP<F5F<U!+`0(4`!0`"``(`&)K7S^`
MLO8/<0$``*X#```^`````````````````*,#``!C;VTN:7-E;F-I82YM971A
M;6]D96QT97-T+VQA=6YC:"]-971A;6]D96Q497-T($QA=6YC:&5R+FQA=6YC
M:%!+`0(4`!0`"``(`&)K7S]5KBD^V@$``!T%```V`````````````````(`%
M``!C;VTN:7-E;F-I82YM971A;6]D96QT97-T+W-R8R]-151!+4E.1B]P97)S
M:7-T96YC92YX;6Q02P$"%``4``@`"`!B:U\_68#X?P(%``"B"P``2@``````
M``````````"^!P``8V]M+FES96YC:6$N;65T86UO9&5L=&5S="]S<F,O8V]M
M+VES96YC:6$O;65T86UO9&5L=&5S="]-971A;6]D96Q497-T+FIA=F%02P$"
M%``4``@`"`!B:U\_!Y94"P,!``#``0``00`````````````````X#0``8V]M
M+FES96YC:6$N;65T86UO9&5L=&5S="]S<F,O8V]M+VES96YC:6$O;65T86UO
M9&5L=&5S="]497-T+FIA=F%02P$"%``4``@`"`!B:U\_,\7J$T$!```.`P``
M2@````````````````"J#@``8V]M+FES96YC:6$N;65T86UO9&5L=&5S="]S
M<F,O8V]M+VES96YC:6$O;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R+FIA
M=F%02P$"%``4``@`"`!B:U\_T5>1^5,!```.!```4P````````````````!C
M$```8V]M+FES96YC:6$N;65T86UO9&5L=&5S="]S<F,O8V]M+VES96YC:6$O
M;65T86UO9&5L=&5S="]497-T0V]N=&%I;F5R0V]N=&%I;F5R+FIA=F%02P4&
2``````D`"0"^`P``-Q(`````
end
Re: Attributes missing in metamodel using IBM JDK [message #754059 is a reply to message #754015] Mon, 31 October 2011 11:44 Go to previous message
James is currently offline James
Very odd, not sure what in the IBM JVM is causing the issue. You can log a bug on EclipseLink with the test and the exact IBM JVM version required.
The meta-model is not normally required, so depending on what you are doing, you may be able to avoid the issue. What are you using the meta-model for?
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:double post
Next Topic:Enumerated(EnumType.String) annotation not working in 2.3.0
Current Time: Wed May 22 21:09:44 EDT 2013
Powered by FUDForum. Page generated in 0.68124 seconds
