| Process Service and Templates [message #753740] |
Fri, 28 October 2011 10:44  |
Bertin Kiekebosch Messages: 223 Registered: August 2011 |
I have created a more complex screen with tabs on it. Each tab contains data out of a template. If I open the form it needs to load the data but it cannot find the form variables.
I guess it has something to do with the formData and the use of the template. The variable used in this processService are almost all coming from the template AbstractPersoonlijkBoxData. I included the ClientFormData and the AbstractPersoonlijkBoxData at the bottom.
I cannot find what is wrong, names seem to be correct. A simple form is working and things seem to be identical.
ProcessingException[ProcessingStatus[ERROR code=0 invoking MPXRid.shared.services.process.IClientProcessService:load / SQL with binds:
SELECT PINUMBER,
INITIALS,
FIRSTNAME,
LASTNAME,
INFIX,
TITLE
FROM CLIENT
WHERE ID = :clientNr
INTO :piNummer,
:initialen,
:voornaam,
:achternaam,
:tussenvoegsel,
:aanroep
IN :clientNr => ? [BIGINT 15903] / Cannot find output for 'ValueOutputToken[piNummer parsed ':piNummer', replaced ':piNummer' into]' in bind base. When selecting into shared context variables make sure these variables are initialized using CONTEXT.set<i>PropertyName</i>(null)]]
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.createOutput(StatementProcessor.java:934)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.<init>(StatementProcessor.java:152)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.createStatementProcessor(AbstractSqlService.java:785)
public class ClientFormData extends AbstractFormData {
private static final long serialVersionUID = 1L;
public ClientFormData() {
public ClientNrProperty getClientNrProperty() {
return getPropertyByClass(ClientNrProperty.class);
* access method for property ClientNr.
public Long getClientNr() {
return getClientNrProperty().getValue();
public void setClientNr(Long clientNr) {
getClientNrProperty().setValue(clientNr);
public PersoonlijkBox getPersoonlijkBox() {
return getFieldByClass(PersoonlijkBox.class);
public class ClientNrProperty extends AbstractPropertyData<Long> {
public ClientNrProperty() {
public class PersoonlijkBox extends AbstractPersoonlijkBoxData {
public PersoonlijkBox() {
@FormData(value = AbstractPersoonlijkBoxData.class, sdkCommand = FormData.SdkCommand.CREATE, defaultSubtypeSdkCommand = FormData.DefaultSubtypeSdkCommand.CREATE)
public abstract class AbstractPersoonlijkBox extends AbstractGroupBox {
protected String getConfiguredLabel() {
return Texts.get("Persoonlijk");
public AanroepField getAanroepField() {
return getFieldByClass(AanroepField.class);
public AchternaamField getAchternaamField() {
return getFieldByClass(AchternaamField.class);
public PiNummerField getPiNummerField() {
return getFieldByClass(PiNummerField.class);
public TussenvoegselField getTussenvoegselField() {
return getFieldByClass(TussenvoegselField.class);
public VoorlettersField getVoorlettersField() {
return getFieldByClass(VoorlettersField.class);
public VoornaamField getVoornaamField() {
return getFieldByClass(VoornaamField.class);
@Order(10.0)
public class PiNummerField extends AbstractStringField {
return Texts.get("PiNummer");
@Order(20.0)
public class AanroepField extends AbstractListBox<Long> {
return Texts.get("Aanroep");
@Order(30.0)
public class VoornaamField extends AbstractStringField {
return Texts.get("Voornaam");
@Order(40.0)
public class VoorlettersField extends AbstractStringField {
return Texts.get("Voorletters");
@Order(50.0)
public class TussenvoegselField extends AbstractStringField {
return Texts.get("Tussenvoegsel");
@Order(60.0)
public class AchternaamField extends AbstractStringField {
return Texts.get("Achternaam");
| Re: Process Service and Templates [message #753805 is a reply to message #753740] |
Fri, 28 October 2011 15:56   |
Ivan Motsch Messages: 82 Registered: March 2010 |
Member |
Maybe can you also post the shared class "AbstractPersoonlijkBoxData".
But i assume it is generated as default box data and the box data is named PersoonlijkBox.
1. did you pass the sql statement the form data object?
2. Since the person box is a template box - which is great -
the INTO variables need to be qualified since the template box is "inside" the formdata.
Only fields directly contained anywhere in the form are accessible top-level on the form data.
All template fields have one indirection, so need to be qualified by their indirection anhcor, the box data.
More simple, change the INTO in the SQL as follows:
SQL.selectInto(
"SELECT PINUMBER,"+
" INITIALS,"+
" FIRSTNAME,"+
" LASTNAME,"+
" INFIX,"+
" TITLE"+
" FROM CLIENT"+
" WHERE ID = :clientNr"+
" INTO :persoonlijkBox.piNummer,"+
" :persoonlijkBox.voorletters,"+
" :persoonlijkBox.voornaam,"+
" :persoonlijkBox.achternaam,"+
" :persoonlijkBox.tussenvoegsel,"+
" :persoonlijkBox.aanroep",
formData <--- THIS IS THE BIND BASE
Does that help?
[Updated on: Fri, 28 October 2011 15:57] Report message to a moderator
| Re: Process Service and Templates [message #753936 is a reply to message #753805] |
Sun, 30 October 2011 16:34  |
Jeremie Bresson Messages: 108 Registered: November 2010 |
You can also do it the other way around:
SQL.selectInto(
"SELECT PINUMBER,"+
" INITIALS,"+
" FIRSTNAME,"+
" LASTNAME,"+
" INFIX,"+
" TITLE"+
" FROM CLIENT"+
" INTO :piNummer,"+
" :voorletters,"+
" :voornaam,"+
" :achternaam,"+
" :tussenvoegsel,"+
" :aanroep",
formData.getPersoonlijkBox() <--- THIS IS THE BIND BASE
If two form datas FirstFormData and SecondFormData share the same template, you can create a method handling the datas contains in the form data with a function working with an instance of AbstractPersoonlijkBoxData.
public void storePersoonlijkBoxData(AbstractPersoonlijkBoxData boxData) {
//handle
Wiki-page (quite empty for the moment) to store informations on templates:
http://wiki.eclipse.org/Scout/Concepts/Template
FUDForum. Page generated in 0.01738 seconds
