Home » Modeling » MOFScript » Call a Java Method from MOFScript transformation(MOFScript)
Call a Java Method from MOFScript transformation [message #746455] Sun, 23 October 2011 08:54 Go to next message
Bea  is currently offline Bea
I want to know if is posible call a Java Method from a MOFScript transformation. I mean, if in a rule i can call the method, and obtains the parameters results of the method, to be used it in the rest of the rule.
I have searched this topic in MOFScript documentation and in the forum but found nothing about this.
Thanks in advance for your response.
Best regards, Beatriz
Re: Call a Java Method from MOFScript transformation [message #753612 is a reply to message #746455] Fri, 28 October 2011 00:48 Go to previous message
Mohsen  is currently offline Mohsen
Hi Bea,
Please read the user guide document section 4.18:
4.18 Invoking External Java Methods
Good luck
Mohsen
Previous Topic:Looking for a working example
Next Topic:MOFScript called from Java API can only transform UML2 3.0.0?
Current Time: Tue May 28 19:10:52 EDT 2013
Powered by FUDForum. Page generated in 0.01555 seconds
