| References to other models [message #744099] |
Fri, 21 October 2011 19:31  |
José Miguel P. Messages: 62 Registered: March 2010 |
Member |
Hello!
My name is José Miguel, and I would like to send a question to the forum. First to all, thanks you for your help.
I have two metamodels, one of they is a "normal metamodel" and in the other, some Eclases have EReferences to Eclass defined in the first metamodel.
* Metamodel 1 => normal
* Metamodel 2 => with Ereferences to Eclases in Metamodel 1
I'm trying do a test for to instance each metamodel and obtain two model, one for each metamodel, using EOL. In my test, I instance metamodel 1 obviously without problem, but when I try instance this Ereferences, I obtain the follow message:
Called feature source on undefined object (..../prueba.eol@67:13)
The question is: Is possible do it using Epsilon?. What is the way of do it?
Thanks you very much for you help!
Best regards.
José Miguel
| Re: References to other models [message #753298 is a reply to message #748556] |
Wed, 26 October 2011 14:01  |
Louis Rose Messages: 427 Registered: July 2009 Location: York, United Kingdom |
Hi José Miguel,
I'm glad it helped, and thanks for the correction! (I think that I forgot the Emfatic syntax for a cross-model reference, specified it in the Ecore, and forgot to regenerate the Emfatic).
Thanks for feedback, and for using Epsilon!
Louis.
FUDForum. Page generated in 0.04990 seconds
