| Mylyn souce code checkout Problem [message #753176] |
Wed, 26 October 2011 13:05  |
MOHAMMAD KHALID FARUQUE AZAM Messages: 19 Registered: February 2011 |
Junior Member |
i have download eclipse using Yoxo5 and wanted to
develop an extension for Mylyn and I am trying to setup a
build workspace for this purpose, as per the instructions given in the
Contributor Reference (http://wiki.eclipse.org/Mylyn_Contributor_Reference).
I completed every single step of this tutoria under setup, but I was unable to compile
the projects. They always produce compilation errors, listed as both Java
Problems and Plug-in Problems. I have set Java 1.5 and I think the Target
Platform and Baseline API are also set correctly. My OS is Windows 7.
| Re: Mylyn souce code checkout Problem [message #753706 is a reply to message #753176] |
Fri, 28 October 2011 08:45  |
Steffen Pingel Messages: 704 Registered: July 2009 |
Which of the target platforms did you activate? Please post the detailed
error messages that your are getting (if you get lots of errors posting 2 or
3 should be sufficient).
Steffen
> unable to compile the projects. They always produce compilation errors,
> listed as both Java Problems and Plug-in Problems. I have set Java 1.5 and
> I think the Target Platform and Baseline API are also set correctly. My OS
> is Windows 7.
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
FUDForum. Page generated in 0.01494 seconds
