| Cairo on HPUX. "Unable to load graphics library" Exception when running SWT application on [message #753106] |
Wed, 26 October 2011 12:31  |
Milan Vahala Messages: 6 Registered: October 2011 |
Junior Member |
I'm using SWT 3.6.2 (swt-3.6.2-motif-hpux-ia64_32) on HPUX 11i v2.
When I run simple SWT application using Cairo (SWT Snippet281 - draw a multi-gradient) I get following exception:
Exception in thread "main" org.eclipse.swt.SWTException: Unable to load graphics library [Cairo required] (java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
no swt-cairo-motif-3659 in java.library.path
no swt-cairo-motif in java.library.path
Can't load library: /var/tmp/swtlib-32/libswt-cairo-motif-3659.so
Can't load library: /var/tmp/swtlib-32/libswt-cairo-motif.so
at org.eclipse.swt.SWT.error(Unknown Source)
at org.eclipse.swt.graphics.Device.checkCairo(Unknown Source)
at org.eclipse.swt.graphics.Pattern.<init>(Unknown Source)
at org.eclipse.swt.snippets.Snippet281$1.handleEvent(Snippet281.java:38)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Composite.XExposure(Unknown Source)
at org.eclipse.swt.widgets.Canvas.XExposure(Unknown Source)
at org.eclipse.swt.widgets.Shell.XExposure(Unknown Source)
at org.eclipse.swt.widgets.Widget.windowProc(Unknown Source)
at org.eclipse.swt.widgets.Display.windowProc(Unknown Source)
at org.eclipse.swt.internal.motif.OS._XtDispatchEvent(Native Method)
at org.eclipse.swt.internal.motif.OS.XtDispatchEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.update(Unknown Source)
at org.eclipse.swt.widgets.Shell.setVisible(Unknown Source)
at org.eclipse.swt.widgets.Shell.open(Unknown Source)
at org.eclipse.swt.snippets.Snippet281.main(Snippet281.java:53)
Caused by: java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
at org.eclipse.swt.internal.Library.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.cairo.Cairo.<clinit>(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:173)
... 19 more
I have Cairo library installed.
The problem seems to be caused by libswt-cairo-motif-3659.so missing in SWT.
swt.jar on Linux and AIX contains libswt-cairo-motif-3659.so file but in HPUX swt.jar it's missing.
Is this the problem and SWT on HPUX does not support Cairo functionality or is problem somewhere else?
Milan
FUDForum. Page generated in 0.01908 seconds
