Home » Eclipse Projects » EclipseLink » create-tables doesn't create foreign key constraints
create-tables doesn't create foreign key constraints [message #746153] Sun, 23 October 2011 04:18 Go to next message
Pablo  is currently offline Pablo
I just noticed that eclipselink is not generating the foreign key constraints for any table.
It does create indexes called FK_XXX_YYY (with the name the FK constraint would have)
See screensjot.
Env:
EL 2.3.0,
MySQL 5.something,
Ubuntu 11.04
Re: create-tables doesn't create foreign key constraints [message #748504 is a reply to message #746153] Mon, 24 October 2011 14:24 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
EclipseLink does create foreign keys (and does not create indexes unless specified). Turn logging on finest and look at the DDL generated, you will see the constraints created.
How did you create your tables?
James : Wiki : Book : Blog
Re: create-tables doesn't create foreign key constraints [message #749678 is a reply to message #748504] Tue, 25 October 2011 07:14 Go to previous messageGo to next message
Thanks James,
I found out the MySQL on ubuntu uses MyISAM storage engine by default which silently ignores foreign key constraints...
U the same James that was answering my questions en toplink two years ago? Wink
If so, good to read you!
Re: create-tables doesn't create foreign key constraints [message #749681 is a reply to message #749678] Tue, 25 October 2011 07:15 Go to previous message
And i could have added that I sorted it out by switching to InnoDB storage engine
Previous Topic:using a sequence connection pool in eclipselink
Next Topic:Problems Executing Stored Procedure in DB2 with EclipseLink v1.2
Current Time: Sat May 18 23:28:21 EDT 2013
Powered by FUDForum. Page generated in 0.01850 seconds
