Home » Eclipse Projects » Web Tools Project (WTP) » Error when launching debugger from Eclipse(Cannot launch JBoss server to debug or run java application)
Error when launching debugger from Eclipse [message #748449] Mon, 24 October 2011 13:47 Go to next message
Billy Blanks is currently offline Billy Blanks
I am new to Eclipse and I am having trouble launching the debugger. Every time I try to launch it, I get the following message: 'Launching JBoss v4.0 at localhost' has encountered a problem. Cannot connect to VM. In the details section of the pop-up is the following text: Cannot connect to VM socket closed. The Eclipse console has the following text: Error occurred during initialization of VM Too small initial heap size. Just trying to run the application from within Eclipse also fails. There is no pop-up however and the message displayed in the Eclipse console is: Error occured during initialization of VM Too small initial heap. This is very strange to me because I am able to launch my server (outside of Eclipse) with no problem.
I am running Windows 7 64-bit, Eclipse Helios R2, Java 1.6.0_27 and JBoss 4.0.3SP1. I hope this problem that I am experiencing isn't so trivial that it wont be answered as I am very much in need of help.
Thank you in advance,
Billy
Re: Error when launching debugger from Eclipse [message #748587 is a reply to message #748449] Mon, 24 October 2011 15:28 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
On 10/24/2011 1:47 PM, Billy Blanks wrote:
> Hello,
> Billy
In the Debug view of the Debug perspective, do you see a terminated
launch for "JBoss v4.0 at localhost". If so, right-click on the
"javaw.exe" item in the tree and select Properties. This dialog will
reveal the command line used to launch JBoss. What are the -Xms and
-Xmx values in this command?
Larry
Re: Error when launching debugger from Eclipse [message #748596 is a reply to message #748587] Mon, 24 October 2011 15:38 Go to previous messageGo to next message
Thank you for the reply Larry. Here are the values:
-Xms128
-Xmx512m
Re: Error when launching debugger from Eclipse [message #748619 is a reply to message #748596] Mon, 24 October 2011 15:59 Go to previous messageGo to next message
> -Xms128
> -Xmx512m
If pasted correctly, it looks like your -Xms value is missing an "m". I
don't know where it went, but 128 bytes isn't going to cut it. To fix,
double-click on the JBoss server in the Servers view. This will open
the server editor. At the bottom of the "General Information" section
(upper left portion of the editor), click the "Open launch
configuration" link. This will open the launch configuration properties
dialog. Switch to the Arguments tab and in the "VM Arguments" section,
add the missing "m" to the "-Xms128".
Larry
Re: Error when launching debugger from Eclipse [message #748687 is a reply to message #748619] Mon, 24 October 2011 17:01 Go to previous message
Larry,
That worked like a charm!
Thanks a lot,
Billy
Previous Topic:How to create a dynamic web project from existing source folders?
Next Topic:Documentation on WTP Runtime framework?
Current Time: Fri May 24 12:19:24 EDT 2013
Powered by FUDForum. Page generated in 0.01969 seconds
