Home » Eclipse Projects » EclipseLink » @OneToMany SortedSet
@OneToMany SortedSet [message #741659] Wed, 19 October 2011 15:15 Go to next message
Marc is currently offline Marc
In order to guarantee preserving the order after any add/remove operation, I'm trying to use a TreeSet attribute under a jpa project as follows :
@OneToMany(mappedBy="b")
private TreeSet<A> manyA;
'A' does implement the Comparable<A> interface.
The problem is that i'm getting the following compile time error :
Target entity for "manyA" is not defined.
If i replace TreeSet by Set the error disappears, i tried the SortedSet interface but still having the same error.
I'm using eclipselink 2.3.0, and Eclipse EE IDE Indigo.
Is there any way to make eclipseLink accept SortedSet mapped attributes?
Re: @OneToMany SortedSet [message #748406 is a reply to message #741659] Mon, 24 October 2011 13:23 Go to previous message
James is currently offline James
Is this a compile error, or just a warning from Eclipse's JPA support?
If you just ignore the warning, does it work?
You can give the targetEntity in the annotation and probably make the warning go away.
JPA only allows Collection, List and Set for collection types, but EclipseLink will support any implementation is you use EAGER. For LAZY support, one of the three interfaces is currently required. You could use Set, and assign a TreeSet to it, however EclipseLink would use its LAZY Set, IndirectSet when restoring from the database.
So try,
@OneToMany(targetEntity=A.class, fetch=EAGER, mappedBy="b")
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:Problem persisting TimestampTZ with JPA
Next Topic:command line tool for generating JPA Entities?
Current Time: Sat May 18 09:36:07 EDT 2013
Powered by FUDForum. Page generated in 0.04043 seconds
