Home » Eclipse Projects » Eclipse 4 » Size constraints in a PartSashContainer
Size constraints in a PartSashContainer [message #744836] Sat, 22 October 2011 07:26 Go to next message
Karl Weber is currently offline Karl Weber
Member
As far as I know, one can put integer numbers in the field Container Data of the children of a PartSashContainer. They determine the relative size a child gets of the size of the parent PartSashContainer.
Now I would like to set an absolute size of one child, or a maximum size. The other children should take the remainder of the space. How can one do this?
If this is not implemented in the model yet, is there a workaround for the SWT renderer?
EDIT:
There seems to be another problem even with relative sizes: One can set the relativ size of one child to 5%. If the application is started, the child gets this 5%, even if the window is maximized. However, if one tries to change the size with the sash, the size of the child jumps to 10% (estimate!). Afterward one cannot set the size of the child below this (estimated) 10%; above that limit, one can change its size at will (well up to 90% at the upper end).
Maybe my approach is wrong: I would like to use a status line in my application. Since this is not present in e4 4.1.1 (I do not use the compatibility mode), I wanted to use an MPart for my own implementation of a status line. Is there a better approach to a status line?
[Updated on: Sat, 22 October 2011 08:26]
Report message to a moderator
Re: Size constraints in a PartSashContainer [message #744988 is a reply to message #744836] Sat, 22 October 2011 09:48 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Hi Karl,
There was a similar question some days ago "how to set minimum size for
windows or parts".
I'm not sure the guy filed a bugzilla, I know I've seen one for min, max
sizes for windows but I can't remember having seen one for containerData.
Would you mind filing one and then post the bug-id to this forum.
Tom
Am 22.10.11 13:26, schrieb Karl Weber:
> one do this?
> the SWT renderer?
Re: Size constraints in a PartSashContainer [message #745143 is a reply to message #744988] Sat, 22 October 2011 12:13 Go to previous message
Member
Since I couldn't find a bug report I filed this one
http://bugs.eclipse.org/bugs/show_bug.cgi?id=361731
This leaves me with the problem of the status line. I know there is a bug report about it, but this does not seem to change anything...
Previous Topic:Controls
Next Topic:How to access the liveeditor
Current Time: Sun May 19 02:51:01 EDT 2013
Powered by FUDForum. Page generated in 0.02839 seconds
