Home » Eclipse Projects » EGit » no supported authentication methods available
no supported authentication methods available [message #735475] Tue, 11 October 2011 20:02 Go to next message
julius  is currently offline julius
hi,
ive added the private key for the gitosis user to
window -> preferences -> general -> network connections -> ssh2
the key is called: user-wf-1
using this as uri:
ssh://opengitrepo@1.2.3.4/laboraufgabe
i get:
i can clone the git repo on a linux box with this command:
git clone ssh://opengitrepo@dmkgit23/laboraufgabe
~/.ssh/config
Host dmkgit23
Hostname 1.2.3.4
User opengitrepo
IdentityFile /home/julius/git/users/user-wf-1
what could be the problem?
Re: no supported authentication methods available [message #737696 is a reply to message #735475] Sat, 15 October 2011 06:14 Go to previous messageGo to next message
im unsure what went wrong but testing this on a different machine with a fresh install worked.
although i used another ssh key, testuser1.
maybe eclipse dislikes - in the username.
Re: no supported authentication methods available [message #740669 is a reply to message #737696] Tue, 18 October 2011 15:10 Go to previous messageGo to next message
again the same problem back on the original system. even with the username that worked on the other xp sp3 installation - same os on both systems
Re: no supported authentication methods available [message #743732 is a reply to message #740669] Fri, 21 October 2011 13:44 Go to previous message
ive upgraded to win7, works finally Smile
Previous Topic:Commit Event Listener
Next Topic:unable to change SSH2 on Ubuntu
Current Time: Fri May 24 05:59:25 EDT 2013
Powered by FUDForum. Page generated in 0.12146 seconds
