Home » Eclipse Projects » Babel » Date pattern translation
Date pattern translation [message #735579] Wed, 12 October 2011 05:33 Go to next message
Arnaud MERGEY is currently offline Arnaud MERGEY
Member
Since I am using babel fr translation of org.eclipse.core.databinding/org/eclipse/core/internal/databinding/messages.properties
I have exceptions above by using databinding in a plugin
I seems following the key DateFormat_DateTime has been translated from dd.MM.yyyy HH:mm:ss.SSS Z to jj.MM.aaaa HH:mm:ss.SSS Z but it is used as a date format pattern. This key should propably be same in fr than english, what do you think ?
java.lang.IllegalArgumentException: Illegal pattern character 'j'
at java.text.SimpleDateFormat.compile(SimpleDateFormat.java:769)
at java.text.SimpleDateFormat.initialize(SimpleDateFormat.java:576)
at java.text.SimpleDateFormat.<init>(SimpleDateFormat.java:501)
at java.text.SimpleDateFormat.<init>(SimpleDateFormat.java:476)
at com.ibm.icu.text.SimpleDateFormat.<init>(SimpleDateFormat.java:218)
at org.eclipse.core.internal.databinding.conversion.DateConversionSupport.<init>(DateConversionSupport.java:45)
at org.eclipse.core.internal.databinding.conversion.StringToDateConverter.<init>(StringToDateConverter.java:24)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.core.databinding.UpdateStrategy.createConverter(UpdateStrategy.java:154)
at org.eclipse.core.databinding.UpdateValueStrategy.fillDefaults(UpdateValueStrategy.java:262)
at org.eclipse.core.databinding.DataBindingContext.bindValue(DataBindingContext.java:162)
The key is http://babel.eclipse.org/babel/translate.php?project=eclipse&version=3.7&file=org.eclipse.core.databinding/org/eclipse/core/internal/databinding/messages.properties&string=DateFormat_DateTime
Arnaud
[Updated on: Wed, 12 October 2011 05:50]
Report message to a moderator
Re: Date pattern translation [message #735610 is a reply to message #735579] Wed, 12 October 2011 07:29 Go to previous messageGo to next message
Kit Lo is currently offline Kit Lo
Member
I agree with that. Is there a test scenario to show the problem?
Would you like to contribute the correction to the Babel database?
Kit Lo
Eclipse Babel Project Lead
Re: Date pattern translation [message #735648 is a reply to message #735610] Wed, 12 October 2011 09:26 Go to previous messageGo to next message
Member
you can reproduce with the attached snippet
The snippet contains a project with target platform and launchers.
You can import the project in a workspace then select target platform defined in target.target, put a debug breakpoint for java.lang.IllegalArgumentException
then launch in debug snippet.i18n.viewapp fr (RCP) you should see the exception while the databinding between date and text in the view.
regarding rhe correction to the babel database, how can i contribute ? should I have to create a bug ?
regards,
Arnaud
Re: Date pattern translation [message #735650 is a reply to message #735648] Wed, 12 October 2011 09:27 Go to previous messageGo to next message
Member
I forgot the snippet
Re: Date pattern translation [message #743409 is a reply to message #735650] Fri, 21 October 2011 08:53 Go to previous message
Member
To contribute the correction, you just have to go to this link:
type in the correct translation, then click the Submit button. Thanks!
Kit Lo
Eclipse babel Project Lead
Previous Topic:ResourceBundleEditor dead?
Next Topic:BIRT translation
Current Time: Tue May 28 22:09:36 EDT 2013
Powered by FUDForum. Page generated in 0.01509 seconds
