Home » Eclipse Projects » Buckminster » Dropping particular SWT into headless Buckminster installation?
Dropping particular SWT into headless Buckminster installation? [message #742596] Thu, 20 October 2011 12:29 Go to next message
Volker Stolz is currently offline Volker Stolz
Member
I've automated builds for our simple Eclipse plugins through a headless Buckminster (3.7) and Hudson for QA purposes, not for building update-sites etc., which works like a charm. Except for the project depending on SWT. Now I've looked at a lot of articles involving SWT, but none of them seem to spell out which bit to get from http://eclipse.org/swt/, or rather http://download.eclipse.org/eclipse/downloads/drops/R-3.7.1-201109091335/index.php#SWT, and where to put it.
I'd be happy to simply make Buckminster do platform-specific builds (Solaris in my case) in a first instance, so I don't mind putting it into Buckminster itself, instead of customizing a platform first---there's no single incantation of './buckminster install' that will do the trick in that case?
-Volker
Re: Dropping particular SWT into headless Buckminster installation? [message #743088 is a reply to message #742596] Fri, 21 October 2011 01:24 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
It should be enough to just include the org.eclipse.rcp feature in your target platform in order to get SWT. The rest
should be fully automatic.
- thomas
> -Volker
Re: Dropping particular SWT into headless Buckminster installation? [message #743250 is a reply to message #743088] Fri, 21 October 2011 05:13 Go to previous messageGo to next message
Member
Thanks Thomas! Following Ralf Ebert's article did the trick---I hadn't realized that defining a platform is so easy.
Volker
PS: Now I'm struggling with the following for a JUnit Plugin Test:
Waiting for jobs to end
junit '-l' 'eu.hatsproject.absplugin/junit.launch' '-o' 'eu.hatsproject.absplugin/junit.xml' '--maxTimeAwaitJunitReport' '20'
ERROR: Plugin validation errors were detected:
{eu.hatsproject.absplugin_0.0.0.qualifier=[Lorg.eclipse.osgi.service.resolver.ResolverError;@1f28aca, org.eclipse.jdt.core_3.7.1.v_OTDT_r201_201109101025=[Ljava.lang.Object;@760a1d, org.eclipse.equinox.preferences_3.4.1.R37x_v20110725=[Ljava.lang.Object;@1920fcc, org.eclipse.osgi_3.7.1.R37x_v20110808-1106=[Ljava.lang.Object;@4b4d26, org.eclipse.equinox.registry_3.5.101.R37x_v20110810-1611=[Ljava.lang.Object;@1b5ff11, org.eclipse.equinox.security_1.1.0.v20110502=[Ljava.lang.Object;@17ce10d}
WARN:  Process /usr/jdk/instances/jdk1.6.0/bin/java (Oct 21, 2011 5:08:37 PM) terminated with exit status 1.
Doing full workspace refresh
java.lang.IllegalArgumentException: Export has failed because no test session is available. (Maybe the argument -maxTimeAwaitJunitReport will help)
Re: Dropping particular SWT into headless Buckminster installation? [message #743365 is a reply to message #743250] Fri, 21 October 2011 07:46 Go to previous message
Member
I've pulled together all the pieces now, and have headless JUnit Plugin tests working---mostly thanks to older postings by Thomas and Ralf's article. Other important insights were:
Configure the JUnit plugin test with features instead of plugins, and eliminate all platform-specific entries from the launch-config, incl. -X VM switches.
Volker
Previous Topic:Additional p2 utilization actor
Next Topic:Buckminster article in Dr.Dobb's
Current Time: Fri May 24 12:25:09 EDT 2013
Powered by FUDForum. Page generated in 0.01621 seconds
