| Re: URL exception [message #757783 is a reply to message #743580] |
Mon, 21 November 2011 11:15  |
Greg Messages: 1 Registered: November 2011 Location: Los Angeles |
Junior Member |
When I try to open a jsp page using the context menu of the JSP file I get the following exception:
at org.eclipse.jst.jsf.common.metadata.query.internal.taglib.TaglibDomainContextImpl.<init>(TaglibDomainContextImpl.java:48)
at org.eclipse.jst.jsf.common.metadata.query.internal.MetaDataQueryContextFactory.createTaglibDomainModelContext(MetaDataQueryContextFactory.java:65)
at org.eclipse.jst.pagedesigner.editors.palette.TagImageManager.getSmallIconImage(TagImageManager.java:80)
at org.eclipse.jst.pagedesigner.converter.jsp.JSPConverterFactory$MyLabelProvider.getImage(JSPConverterFactory.java:96)
at org.eclipse.jst.pagedesigner.converter.HiddenTagConverter.getVisualImage(HiddenTagConverter.java:91)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.createHiddenProvider(ElementEditPart.java:238)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.refresh(ElementEditPart.java:275)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.refresh(ElementEditPart.java:264)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.jst.pagedesigner.parts.NodeEditPart.addNotify(NodeEditPart.java:104)
at org.eclipse.jst.pagedesigner.parts.ElementEditPart.addNotify(ElementEditPart.java:155)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refreshChildren(DocumentEditPart.java:134)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refreshChildren(DocumentEditPart.java:126)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.jst.pagedesigner.parts.DocumentEditPart.refresh(DocumentEditPart.java:114)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.jst.pagedesigner.editors.SimpleGraphicalEditor.setModel(SimpleGraphicalEditor.java:430)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.connectDesignPage(HTMLEditor.java:364)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.createPages(HTMLEditor.java:444)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.ui.ide.IDE.openInternalEditorOnFileStore(IDE.java:1216)
at org.eclipse.ui.internal.ide.application.DelayedEventsProcessor$1.run(DelayedEventsProcessor.java:106)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
I am using eclipse version version 3.7.0 build I20110613-1736 with the Oracle Enterprise Pack for Eclipse version 11.1.1.7.3
This is really frustrating. Any help would be greatly appreciated.
Greg
FUDForum. Page generated in 0.01529 seconds
