| Swt Print Preview [message #740431] |
Tue, 18 October 2011 10:00  |
rajeev Messages: 4 Registered: October 2011 |
Junior Member |
I embed word document in applet using swt. in that all optiuons are working fine other than print preview option. i create a swt button and assign functionality for print preview
olecs.exec(OLE.OLECMDID_PRINTPREVIEW, OLE.OLECMDEXECOPT_PROMPTUSER, null, null);
but it was not excuted and mean while it didnt gave any exception too.please help me out how to do print preview function in word ole
| Re: Swt Print Preview [message #741061 is a reply to message #740431] |
Wed, 19 October 2011 02:32   |
Vijay Raj Messages: 605 Registered: July 2009 |
try this
OleAutomation automation = new OleAutomation(clientSite);
// looks up the ID for method Select.
int[] methodIDs = automation.getIDsOfNames(new String[]{"PrintPreview"});
int methodID = methodIDs[0];
Variant result = automation.invoke(methodID);
automation.dispose();
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
| Re: Swt Print Preview [message #741262 is a reply to message #741179] |
Wed, 19 October 2011 06:55   |
whats different in your code??
This is working for me..
import java.applet.Applet;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.ole.win32.OleAutomation;
import org.eclipse.swt.ole.win32.Variant;
import org.eclipse.swt.widgets.Button;
public class Snippet157 extends Applet {
org.eclipse.swt.widgets.Display display;
org.eclipse.swt.widgets.Shell swtParent;
java.awt.Canvas awtParent;
public void init() {
Thread thread = new Thread(new Runnable() {
public void run() {
setLayout(new java.awt.GridLayout(1, 1));
awtParent = new java.awt.Canvas();
add(awtParent);
display = new org.eclipse.swt.widgets.Display();
swtParent = org.eclipse.swt.awt.SWT_AWT.new_Shell(display,
awtParent);
swtParent.setLayout(new org.eclipse.swt.layout.FillLayout());
org.eclipse.swt.ole.win32.OleFrame frame = new org.eclipse.swt.ole.win32.OleFrame(
swtParent, org.eclipse.swt.SWT.NONE);
final org.eclipse.swt.ole.win32.OleClientSite site;
try {
site = new org.eclipse.swt.ole.win32.OleClientSite(frame,
org.eclipse.swt.SWT.NONE, "Word.Document");
Button b = new Button(swtParent, SWT.PUSH);
b.setText("Print");
b.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
OleAutomation automation = new OleAutomation(site);
System.out.println(result != null ? "Successful" : "Failed");
System.out.println(result);
public void widgetDefaultSelected(SelectionEvent e) {
// TODO Auto-generated method stub
} catch (org.eclipse.swt.SWTException e) {
String str = "Create OleClientSite Error" + e.toString();
System.out.println(str);
return;
setSize(500, 500);
validate();
site.doVerb(org.eclipse.swt.ole.win32.OLE.OLEIVERB_SHOW);
while (swtParent != null && !swtParent.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
thread.start();
public void stop() {
if (display != null && !display.isDisposed()) {
display.syncExec(new Runnable() {
public void run() {
if (swtParent != null && !swtParent.isDisposed())
swtParent.dispose();
swtParent = null;
display.dispose();
display = null;
remove(awtParent);
awtParent = null;
Vijay
| Re: Swt Print Preview [message #743033 is a reply to message #742448] |
Fri, 21 October 2011 00:06  |
By the way ,to avoid all this version problems,u should open your PDF,word etc files in a browser..and from there you could print or print preview them easily.(unless u want word specific handling)
offcoarse there are many preconditions for this to work,but this approach avoids all the version specific handling and then again you already have a precondition of word should be installed on the system..
Vijay
[Updated on: Fri, 21 October 2011 01:13] Report message to a moderator
FUDForum. Page generated in 0.01751 seconds
