Home » Eclipse Projects » Equinox » Swing classes not found when using DS
Swing classes not found when using DS [message #100340] Thu, 25 October 2007 13:20 Go to next message
Michael Furtak is currently offline Michael Furtak
I am trying out the Declarative Services functionality from the equinox
3.4 I20071023-0800 build and am running into some class loading problems.
I have a bundle that winds up affecting some Swing classes (menu items).
It produces errors now that I have switched it to use DS instead of the
Service Activator Toolkit. The error is:
UIDefaults.getUI() failed: no ComponentUI class for: javax.swing.JMenuItem
This has to do with Swing not being able to find the correct UI classes if
you are not using the default LaF. (Just changing it to the System LaF is
enough to produce this.)
My question is this: Why does this happen with DS and not with the SAT?
Is DS ignoring the bundle's DynamicImport-Package: * statement? (This is
the only way I've found to solve these issues.)
Any insight would be appreciated.
-Mike
Re: Swing classes not found when using DS [message #734632 is a reply to message #100340] Sat, 08 October 2011 20:10 Go to previous messageGo to next message
pfxo  is currently offline pfxo
I have the same error if I use Java Swing inside bundles. If I start my bundle activator without Spring DM, all work good. But as far as I use Spring DM, I get always this UIDefaults.getUI() failed: no ComponentUI class for: javax.swing.JPanel... errors.
But I found a solution on this post: www.eclipse.org/forums/index.php/mv/msg/142233/448472/#msg_448472
You need to write
UIManager.put("ClassLoader", getClass().getClassLoader());
before you use Swing. I don't know why this error happen only in coherence with Spring DM.
Re: Swing classes not found when using DS [message #742224 is a reply to message #734632] Thu, 20 October 2011 05:46 Go to previous message
Ivan Larionov is currently offline Ivan Larionov
Member
Have you tried ?
Import-Package: javax.swing,...
> You need to write UIManager.put("ClassLoader",
> getClass().getClassLoader()); before you use Swing. I don't know why
Previous Topic:Eclipse Update Site Mirror Tool
Next Topic:Equinox newbie. please help!
Current Time: Fri May 24 15:59:05 EDT 2013
Powered by FUDForum. Page generated in 0.01470 seconds
