Home » Eclipse Projects » EGit » unable to change SSH2 on Ubuntu
unable to change SSH2 on Ubuntu [message #742194] Thu, 20 October 2011 05:10 Go to next message
Niezly  is currently offline Niezly
I use "git" user to connect to the repository. I've changed the SSH2 home to /home/git/.ssh (Preferences->General->Network Connections->SSH) and added "id_dsa" file. Unfortunately when trying to connect I receive the following error:
ssh://git@<host>/some/path/Project: java.io.FileNotFoundException: /home/<MY_HOME>/.ssh/id_dsa (No such file or directory)
form CLI it works fine. for EGit I've found a workaround(but not a very convenient one)
if I copy "id_dsa" from git/.ssh to <MY_HOME>/.ssh it works ;/
any ideas how to fix it?
my configuration:
Ubuntu 10.04 LTS (Lucid Lynx) 64bit
Eclipse Indigo build 20110916-0149
EGit 1.1.0.201109151100-r
Re: unable to change SSH2 on Ubuntu [message #742772 is a reply to message #742194] Thu, 20 October 2011 16:28 Go to previous messageGo to next message
Manuel Doninger is currently offline Manuel Doninger
In Window -> Preferences -> General -> Network -> SSH you can configure the directory where EGit/Eclipse looks for the SSH keys. But why do you create a local user git to access the repository? You only need that user on the server where the repositories are stored. Then you simply save the private SSH keys, which have the rights to sign in with the git user, in the .ssh folder of your user account.
Re: unable to change SSH2 on Ubuntu [message #747821 is a reply to message #742772] Mon, 24 October 2011 05:56 Go to previous message
it seems those settings are ignored. EGit always chooses "id_dsa" from HOME.
for various evil reasons Twisted Evil
Previous Topic:no supported authentication methods available
Next Topic:commit gui reformats modified hard-wrapped text badly
Current Time: Thu May 23 19:26:03 EDT 2013
Powered by FUDForum. Page generated in 0.02150 seconds
