| Resetting daemon status at the database level [message #742098] |
Thu, 20 October 2011 03:03 |
Srinivasan Iyer Messages: 34 Registered: October 2011 |
Member |
The following section outlines how to turn off a daemon (event daemon, timer trigger, email trigger) that has been started for the first time using SQL commands:
The daemon_log table will show two entries per daemon type.
One entry shows, when the daemon has been initially started (code=0) and the other entry shows, when the daemon has been executed the last time (code=1).
If you want to "stop" daemons on database level, you have to execute SQL statement below.
update DAEMON_LOG set state = 0, stamp = 0 where code = 0;
This will of course not stop the daemon thread immediately, but the next time a daemon is scheduled, the daemon_log table is checked upfront. If state and stamp are set to 0, no new daemon thread will be kicked off.
[Updated on: Thu, 20 October 2011 04:27] Report message to a moderator
FUDForum. Page generated in 0.01523 seconds
