| Problem persisting TimestampTZ with JPA [message #737095] |
Fri, 14 October 2011 12:52  |
Jeremy Purdy Messages: 7 Registered: October 2011 |
Junior Member |
Versions
Eclipselink 2.1
Oracle 10.2.0.4
Tomcat 5.5.26
Using JPA, I am attempting to persist a java.util.Calendar object to an Oracle Timestamp With Time Zone column. From what I have read, Eclipselink is supposed to just handle this for Oracle DB.
However, an attempt at a direct mapping:
@Entity
@Table(name="TIMESTAMP_TZ_TEST")
public class TimestampTzTest {
@Id
private Long id;
@Column(name="TIME")
private Calendar time;
public Long getId() {
return id;
public void setId(Long id) {
this.id = id;
public Calendar getTime() {
return time;
public void setTime(Calendar time) {
this.time = time;
fails during startup because
The attribute [time] from the entity class [class eg.model.TimestampTzTest] does not specify a temporal type.
Next, I try using a TypeConverter
@Convert("timestamptz")
@TypeConverter(name="timestamptz", dataType=TIMESTAMPTZ.class)
This results in an error during execution:
Caused by: java.lang.ClassCastException: org.apache.tomcat.dbcp.dbcp.DelegatingCallableStatement cannot be cast to oracle.jdbc.OracleCallableStatement
at oracle.sql.TRANSDUMP.getTransitions(TRANSDUMP.java:42)
at oracle.sql.TIMEZONETAB.updateTable(TIMEZONETAB.java:456)
at oracle.sql.TIMESTAMPTZ.toTimestamp(TIMESTAMPTZ.java:571)
at oracle.sql.TIMESTAMPTZ.timestampValue(TIMESTAMPTZ.java:731)
at org.eclipse.persistence.platform.database.oracle.Oracle9Platform.getTIMESTAMPTZFromResultSet(Oracle9Platform.java:192)
From what I have found during search, this appears to be caused by the Tomcat connection pool not returning the underlying OracleCallableStatement.
I have not been able to find a solution to this problem. Can someone please guide me?
| Re: Problem persisting TimestampTZ with JPA [message #739728 is a reply to message #737095] |
Mon, 17 October 2011 15:49   |
James Sutherland Messages: 1834 Registered: July 2009 |
To support TIMESTAMPTZ EclipseLink needs access to the real JDBC connection.
If you are using a DataSource you need to set a ServerPlatform in EclipseLink that can unwrap the connection.
Log an enhancement request to have a platform added for Tomcat, it should be pretty simple to implement, so consider contributing it if you do.
James : Wiki : Book : Blog
| Re: Problem persisting TimestampTZ with JPA [message #741542 is a reply to message #739865] |
Wed, 19 October 2011 12:21  |
Junior Member |
It took a while to figure out how to unwrap the Tomcat DBCP Connection, until I found out that Spring has a helper method to do it. Here is my implemented TomcatServerPlatform, which has not been fully tested but works for this current scenario:
import java.sql.Connection;
import java.sql.SQLException;
import org.eclipse.persistence.platform.server.ServerPlatformBase;
import org.eclipse.persistence.sessions.DatabaseSession;
import org.springframework.jdbc.support.nativejdbc.CommonsDbcpNativeJdbcExtractor;
public class TomcatServerPlatform extends ServerPlatformBase {
public TomcatServerPlatform(DatabaseSession newDatabaseSession) {
super(newDatabaseSession);
@SuppressWarnings("unchecked")
public Class getExternalTransactionControllerClass() {
return null;
public Connection unwrapConnection(Connection connection) {
CommonsDbcpNativeJdbcExtractor nje = new CommonsDbcpNativeJdbcExtractor();
try {
connection = nje.getNativeConnection(connection);
} catch (SQLException e) {
// TODO Auto-generated catch block
e.printStackTrace();
return connection;
Configuring JPA to utilize this class requires the following properties within the persistence.xml:
<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.oracle.Oracle10Platform"/>
<property name="eclipselink.target-server" value="data.jpa.eclipselink.support.TomcatServerPlatform"/>
Using the TypeConverter annotation listed previously this works properly and I am able to persist the Calendar object to a TIMESTAMP WITH TIME ZONE column.
Note that this implementation requires that you are using Spring. Because of this, this solution would not be a valid consideration to be included in Eclipselink for general use. I have been largely unsuccessful in unwrapping the DBCP connection without this Spring helper. If someone wants to try to figure that out, feel free.
FUDForum. Page generated in 0.01619 seconds
