Home » Eclipse Projects » EclipseLink » orm.xml - customizing table name
orm.xml - customizing table name [message #740421] Tue, 18 October 2011 09:49 Go to next message
Mauro Flores is currently offline Mauro Flores
Member
How do I write an orm.xml file to customize only the name of the database table mapped to an entity?
Any other mapping I want to configure using annottation.
Does anybody has an example?
Thanks. Mauro.
Re: orm.xml - customizing table name [message #740491 is a reply to message #740421] Tue, 18 October 2011 11:10 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris Delahunt
The orm.xml file is merged overtop of the annotations, so you only need to define what you need to have changed. A simple orm.xml might look like:
<entity-mappings version="2.0" xmlns="http://java.sun.com/xml/ns/persistence/orm" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm orm_2_0.xsd">
    <entity name="EntityName" class="package.Entity" access="PROPERTY">
        <table name="TABLE_NAME"/>
    </entity>
</entity-mappings>
Best Regards,
Chris
Re: orm.xml - customizing table name [message #740493 is a reply to message #740421] Tue, 18 October 2011 11:10 Go to previous messageGo to next message
</entity>
</entity-mappings>
Best Regards,
Chris
Re: orm.xml - customizing table name [message #740675 is a reply to message #740493] Tue, 18 October 2011 15:21 Go to previous messageGo to next message
Member
Thanks, Chris. It almost worked.
Unfortunally two annottations were ignored:
1) @Temporal
  @Temporal(TemporalType.TIMESTAMP)
  @Column(name = "DATA_HORA")
  private Calendar          dataHora;
Exception Description: The attribute [dataHora] from the entity class [class X] does not specify a temporal type. A temporal type must be specified for persistent fields or properties of type java.util.Date and java.util.Calendar.
at org.eclipse.persistence.exceptions.ValidationException.noTemporalTypeSpecified(ValidationException.java:1375)
2) @Id
  @Id
  @Column(name = "NRO_INT_AUDITORIA")
  private Long              nroIntAuditoria;
Exception Description: Entity class [class X] has no primary key specified. It should define either an @Id, @EmbeddedId or an @IdClass. If you have defined PK using any of these annotations then make sure that you do not have mixed access-type (both fields and properties annotated) in your entity class hierarchy.
I will try now to define this two information redundantly in orm.xml:
<entity-mappings xmlns="http://java.sun.com/xml/ns/persistence/orm"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm http://java.sun.com/xml/ns/persistence/orm_1_0.xsd"
	version="1.0">
	<entity name="EntityName" class="X"
		access="PROPERTY">
		<table name="TABLE" />
		<attributes>
			<id name="nroIntAuditoria"></id>
			<basic name="dataHora"><temporal>TIMESTAMP</temporal></basic>
		</attributes>
	</entity>
</entity-mappings>
[Updated on: Tue, 18 October 2011 15:22]
Report message to a moderator
Re: orm.xml - customizing table name [message #740684 is a reply to message #740675] Tue, 18 October 2011 15:35 Go to previous message
Member
My mistake, Chris! Ignore my last post.
Your solution worked.
In my first try I was using access="PROPERTY" and I should use "FIELD".
	version="1.0">
	<entity name="AuditoriaED" class="X"
		access="FIELD">
	</entity>
</entity-mappings>
Thanks.
Re: orm.xml - customizing table name [message #740686 is a reply to message #740675] Tue, 18 October 2011 15:35 Go to previous message
Mauro is currently offline Mauro
Member
version="1.0">
access="FIELD">
</entity>
</entity-mappings>
Thanks.
Previous Topic:what maven artefact for (DynamicJaxbContext with xsd) ...jaxb.dynamic.metadata.SchemaMetadata
Next Topic:Problem with @OneToMany from an @Embeddable
Current Time: Sat May 18 05:39:08 EDT 2013
Powered by FUDForum. Page generated in 0.10114 seconds
