Home » Eclipse Projects » Eclipse Process Manager (Stardust) » TypeMismatchException for javax.transaction.UserTransaction during server start on JBoss(Problems using jtaTxManager in Spring application context with EAR deployment on JBoss)
TypeMismatchException for javax.transaction.UserTransaction during server start on JBoss [message #740369] Tue, 18 October 2011 08:39 Go to next message
Jan Hendrik Scheufen is currently offline Jan Hendrik Scheufen
Member
I'm trying to startup a spring context via the ContextLoaderListener inside web.xml of the processportal.war. The WAR is deployed as part of an EAR in a JBOSS EJB context.
One of the declared beans is a transaction manager:
<bean id="txManager" class="org.springframework.transaction.jta.JtaTransactionManager">
    <property name="transactionManagerName" value="java:/TransactionManager"/>
    <property name="userTransactionName" value="UserTransaction"/>
</bean>
During server startup I get this exception:
11:31:43,359 INFO [TomcatDeployment] deploy, ctxPath=/xxx/processPortal
11:31:43,734 INFO [[/xxx/processPortal]] Initializing Spring root WebApplicationContext
11:31:43,734 INFO [ContextLoader] Root WebApplicationContext: initialization started
11:31:43,781 INFO [XmlWebApplicationContext] Refreshing org.springframework.web.context.support.XmlWebApplicationContext@13c6451: display name [Root WebApplicationContext]; startup date [Fri Oct 30 11:31:43 EDT 2009]; root of context hierarchy
11:31:43,859 INFO [XmlBeanDefinitionReader] Loading XML bean definitions from class path resource [xxx-spring-context.xml]
11:31:43,984 INFO [XmlWebApplicationContext] Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@13c6451]: org.springframework.beans.factory.support.DefaultListableBeanFactory@11787de
11:31:44,218 INFO [DefaultListableBeanFactory] Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@11787de: defining beans [ConstantsService,RulesService,MSQLDataSource,txManager,SampleDAO]; root of factory hierarchy
11:31:44,312 INFO [DefaultListableBeanFactory] Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@11787de: defining beans [ConstantsService,RulesService,MSQLDataSource,txManager,SampleDAO]; root of factory hierarchy
11:31:44,312 ERROR [ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'txManager' defined in class path resource [xxx-spring-context.xml]: Invocation of init method failed; nested exception is org.springframework.transaction.TransactionSystemException: JTA UserTransaction is not available at JNDI location [UserTransaction]; nested exception is org.springframework.jndi.TypeMismatchNamingException: Object of type [class org.jboss.tm.usertx.client.ServerVMClientUserTransaction] available at JNDI location [UserTransaction] is not assignable to [javax.transaction.UserTransaction]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1336)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:471)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:220)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3910)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4393)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeployInternal(TomcatDeployment.java:312)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeploy(TomcatDeployment.java:144)
at org.jboss.web.deployers.AbstractWarDeployment.start(AbstractWarDeployment.java:461)
at org.jboss.web.deployers.WebModule.startModule(WebModule.java:118)
at org.jboss.web.deployers.WebModule.start(WebModule.java:97)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668)
at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206)
at $Proxy36.start(Unknown Source)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348)
at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1598)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1062)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553)
at org.jboss.system.ServiceController.doChange(ServiceController.java:688)
at org.jboss.system.ServiceController.start(ServiceController.java:460)
at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46)
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50)
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1210)
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098)
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781)
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:698)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.loadProfile(ProfileServiceBootstrap.java:304)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:205)
at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:405)
at org.jboss.Main.boot(Main.java:209)
at org.jboss.Main$1.run(Main.java:547)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.springframework.transaction.TransactionSystemException: JTA UserTransaction is not available at JNDI location [UserTransaction]; nested exception is org.springframework.jndi.TypeMismatchNamingException: Object of type [class org.jboss.tm.usertx.client.ServerVMClientUserTransaction] available at JNDI location [UserTransaction] is not assignable to [javax.transaction.UserTransaction]
at org.springframework.transaction.jta.JtaTransactionManager.lookupUserTransaction(JtaTransactionManager.java:568)
at org.springframework.transaction.jta.JtaTransactionManager.initUserTransactionAndTransactionManager(JtaTransactionManager.java:444)
at org.springframework.transaction.jta.JtaTransactionManager.afterPropertiesSet(JtaTransactionManager.java:431)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1367)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1333)
... 74 more
Caused by: org.springframework.jndi.TypeMismatchNamingException: Object of type [class org.jboss.tm.usertx.client.ServerVMClientUserTransaction] available at JNDI location [UserTransaction] is not assignable to [javax.transaction.UserTransaction]
at org.springframework.jndi.JndiTemplate.lookup(JndiTemplate.java:157)
at org.springframework.transaction.jta.JtaTransactionManager.lookupUserTransaction(JtaTransactionManager.java:565)
... 78 more
World Wide Web tells me to look for libraries that also implement JTA interfaces (like jta.jar) in my application.
http://www.jroller.com/raible/entry/spring_s_jtatransactionmanager_on_jboss
http://www.jboss.org/?module=bb&op=viewtopic&t=69587
[Updated on: Thu, 20 October 2011 09:40]
Report message to a moderator
Re: TypeMismatchException for javax.transaction.UserTransaction during server start on JBoss [message #740373 is a reply to message #740369] Tue, 18 October 2011 08:43 Go to previous message
Member
So I looked for anything with jta in its name in my webapp and found a few JARs called geronimo-* and removed them. This fixed the problem.
The Geronimo libs made their way into the WEB-INF/lib folder accidentaly, because I initially started off with a Dynamic Web Project and the libs were needed for Tomcat deployment, but not on JBoss.
Current Time: Mon May 20 03:57:05 EDT 2013
Powered by FUDForum. Page generated in 0.01500 seconds
