Home » Eclipse Projects » Virgo » Eclipse Server Runtime Environment for Virgo (Jetty) 3.0.1
Eclipse Server Runtime Environment for Virgo (Jetty) 3.0.1 [message #737895] Sat, 15 October 2011 11:49 Go to next message
Mark Elliot is currently offline Mark Elliot
When I attempt to start Virgo Jetty 3.0.1 using the Eclipse Virgo Web Server v2.1 Server Runtime Environment (Server Adapter), the web engine seems to fail to run; in particular, the web admin console is not accessible (no response from the server). When I run manually using the startup.bat script in the bin directory the admin console is accessible.
I don't experience this issue with Virgo Tomcat 3.0.1, but I need to use Jetty to avoid having to go to Servlet 3.0.
- Is there an Eclipse Server Adapter for Virgo Jetty 3.0.1?
- If not, what do I need to do to get Virgo Jetty 3.0.1 running from Eclipse? (for development purposes)
Re: Eclipse Server Runtime Environment for Virgo (Jetty) 3.0.1 [message #738740 is a reply to message #737895] Sun, 16 October 2011 13:39 Go to previous messageGo to next message
Chris Frost is currently offline Chris Frost
The Virgo tooling only supports the Tomcat version of Virgo but it can be made to work by modifying some of the VM args of the server. You need to add jetty.home and have it point to the the jetty directory in your Virgo install. If that doesn't work then check the log file in the serviceability folder and see what errors there are, paste them up here and I should be able to help.
Chris
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Eclipse Server Runtime Environment for Virgo (Jetty) 3.0.1 [message #739859 is a reply to message #738740] Mon, 17 October 2011 19:33 Go to previous message
Awesome -- so I added jetty.home and I'm up. Perfect, thanks.
Will the tooling support the Jetty version in the future? Also, it might be nice if the wiki page on tooling indicated in only supports the Tomcat version.
Previous Topic:Uses Violation: Conflicting Packages from Kernel and User Region
Next Topic:Simple WAR (VAADIN) problem
Current Time: Fri May 24 17:34:58 EDT 2013
Powered by FUDForum. Page generated in 0.01688 seconds
