| DataTextDropListener drop behavior changed [message #739598] |
Mon, 17 October 2011 12:36  |
Carl Messages: 1 Registered: October 2011 |
Junior Member |
Last year I integrated BIRT 2.3.2 into our product so that customers could use the chart wizard to create/manage their own charts. Upon upgrading eclipse to 3.7, we upgraded BIRT to 3.7 as well. While testing the chart wizard, I noticed that the drag/drop to the x/y axis fields no longer works. Specifically, the code that assigns the value has been commented out of DataTextDropListener.
public void drop( DropTargetEvent event )
String bindingName = (String) event.data;
// Since in Mac os X/ Linux, the dragEnter method did not validate
// expression, so
// here validate the expression.
if ( !Platform.OS_WIN32.equals( Platform.getOS( ) ) )
ExpressionCodec expCodec = ChartModelHelper.instance( )
.createExpressionCodec( );
expCodec.setBindingName( bindingName, btnBuilder.isCube( ) );
if ( !DataDefinitionTextManager.getInstance( )
.isValidExpression( txtDataDefn, expCodec.getExpression( ) ) )
return;
btnBuilder.setBindingName( bindingName, true );
// String expression = (String) event.data;
// // If it's last element, remove color binding
// if ( !expression.equals( ChartUIUtil.getText( txtDataDefn ) )
// && DataDefinitionTextManager.getInstance( )
// .getNumberOfSameDataDefinition( ChartUIUtil.getText( txtDataDefn ) )
// == 1 )
// ColorPalette.getInstance( ).retrieveColor( ChartUIUtil.getText(
// txtDataDefn ) );
// // Check if dragged expression can be put on target series. For
// sharing
// // binding case, Y optional only allow grouped binding.
// if ( !DataDefinitionTextManager.getInstance( )
// .isValidExpression( txtDataDefn, expression ) )
// return;
// btnBuilder.setExpression( expression );
// DataDefinitionTextManager.getInstance( ).updateQuery( txtDataDefn );
// // Refresh all data definition text
// DataDefinitionTextManager.getInstance( ).refreshAll( );
Can anyone explain to me why this code was commented out? Is there a work-around?
Carl
| Re: DataTextDropListener drop behavior changed [message #739631 is a reply to message #739598] |
Mon, 17 October 2011 13:16  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
I am not certain why this was commented out. Can you open a bugzilla
entry with the question?
Jason
> // expression, so
> // here validate the expression. if ( !Platform.OS_WIN32.equals(
> return;
> // == 1 )
> // txtDataDefn ) );
> // sharing
> // return;
> work-around?
> Carl
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01517 seconds
