| hiding column after rendering [message #733849] |
Wed, 05 October 2011 15:22  |
Tobbi Filteau Messages: 10 Registered: September 2011 |
Junior Member |
Hi there,
I'm creating a BIRT report that's supposed to display my company's clients expenses. I'm using a table and the lines are used to give the different divisions of a client while the columns are used to display the different categories of expenses.
The problem I have is that not all clients have every expense categories, so a lot of the columns end up being filled with zeroes. I essentially want to hide those said columns... but I can only tell if a column is filled with 0 AFTER it's actually rendered at which point it's too late for the visibility property to kick in.
Is there another way of proceeding with this?
Thanks in advance
Osu
FUDForum. Page generated in 0.01984 seconds
