Home » Eclipse Projects » EPF » compiling epf composer plugin
compiling epf composer plugin [message #28422] Fri, 02 February 2007 08:22 Go to next message
danny foncke is currently offline danny foncke
Member
Who came up with the idea to use 'plugin' for 'method plugin' when
implemented in a framework that itself is based on plugins (exclipse
plugins ) :)
anyway, I succeeded in having the EPF eclipse plugins available in my
Eclipse. All dependencies solved, no problems reported
The plugin under investigation : org.eclipse.epf.publishing
Afer changing the source of the plugin a bit (adding 1 little logging
line) -> how do I get this changed plugin (Eclipse plugin, that is) in
my regular EPF ?
thks
Danny
Re: compiling epf composer plugin [message #28961 is a reply to message #28422] Fri, 02 February 2007 11:35 Go to previous messageGo to next message
Eclipse User
Originally posted by: storaskar.xx.xxx.xxx
I assume that you have checkout out EPF source code into Eclipse workbench
and modified "publishing" plugin. If that's the case, you could just use
Eclipse Export->Plug-in Development->Deployable Plug-in and framgments.
Choose whichever plugin you want, export as JAR file. You can drop that
jar file on your regular EPF jar file. And start using it. This is
standard way of exporting plugins/building jars. If you need more
information, you should be able to get that from main Eclipse site.
Hope it helps.
Shilpae
Re: compiling epf composer plugin [message #28998 is a reply to message #28961] Tue, 06 February 2007 03:20 Go to previous messageGo to next message
Member
It does, thanks a lot
> workbench and modified "publishing" plugin. If that's the case, you
> could just use Eclipse Export->Plug-in Development->Deployable Plug-in
> and framgments. Choose whichever plugin you want, export as JAR file.
> You can drop that jar file on your regular EPF jar file. And start using
> it. This is standard way of exporting plugins/building jars. If you need
> more information, you should be able to get that from main Eclipse site.
> Hope it helps.
> Shilpae
Re: compiling epf composer plugin [message #30030 is a reply to message #28422] Thu, 15 February 2007 09:18 Go to previous messageGo to next message
Aitor Bediaga is currently offline Aitor Bediaga
Hi Danny, I'm trying also to have the EPF Composer integrated in my
Integrated Development Environment (Eclipse) as an Eclipse plugin. Can you
explain us how do you manage to do this?
Thank you in advance,
Aitor Bediaga.
Re: compiling epf composer plugin [message #575899 is a reply to message #28422] Fri, 02 February 2007 11:35 Go to previous messageGo to next message
Shilpa Toraskar is currently offline Shilpa Toraskar
Hope it helps.
Shilpae
Re: compiling epf composer plugin [message #575921 is a reply to message #28961] Tue, 06 February 2007 03:20 Go to previous messageGo to next message
Member
> Hope it helps.
> Shilpae
Re: compiling epf composer plugin [message #576418 is a reply to message #28422] Thu, 15 February 2007 09:18 Go to previous messageGo to next message
Aitor Bediaga.
Re: compiling epf composer plugin [message #739307 is a reply to message #28961] Mon, 17 October 2011 06:25 Go to previous message
gurgentugba is currently offline gurgentugba
But I can not understand that sentencs is "You can drop that jar file on your regular EPF jar file." Because I don't find EPF as a jar file. Can u help me please in this issue?
Previous Topic:epf - eclipse development a plugin
Next Topic:Errors in building EPF Composer?
Current Time: Mon May 20 15:28:55 EDT 2013
Powered by FUDForum. Page generated in 0.01784 seconds
