Home » Modeling » UML2 Tools » Does class diagram support Chinese characters?(When named a class in Chinese, the name is not rendered properly on class diagram.)
Does class diagram support Chinese characters? [message #735201] Tue, 11 October 2011 04:20 Go to next message
zighouse  is currently offline zighouse
Changes a class' name into Chinese on class diagram, and the name in the class notation dispeared. For example:
1. drop a class into the class diagram;
2. and rename it as '实物';
3. and then, it displayed a class notation with blank name on diagram.
While, in .uml file which encoding as utf-8, there is a class named as '实物' correctly. So as the name shown in project explorer window for .umlclass correctly.
Save it as image file, and get a correctly named png image.
figure1: eclipse window
index.php/fa/4209/0/
figure2: saved as image file
index.php/fa/4210/0/
UML2 Tools SDK (Incubation), version: 0.9.0.v200906190654
Is it a registered or fixed bug? Or it is not considered as a bug?
[Updated on: Tue, 11 October 2011 05:45]
Report message to a moderator
Re: Does class diagram support Chinese characters? [message #736164 is a reply to message #735201] Thu, 13 October 2011 12:55 Go to previous message
Make sure that you have set your project to be UTF-8 and if that doesn't
fix it submit a bug.
Ed Willink
Previous Topic:Problem installing UML Tools on Eclipse Galileo
Next Topic:About state charts, how can I add entry/exit/do/transitions actions?
Current Time: Sat May 25 07:08:12 EDT 2013
Powered by FUDForum. Page generated in 0.01612 seconds
